see the Clyude Ring Netter file ... 3/4in to 1ft scale (hull about 41-in overall) is entirely fastened using dowells. Have used this technique successfully several times
feedstock is the humble cocktail stick, though a really large model could justify use of kebab skewer size
important, DO NOT use bamboo if hull planking is bog ordinary pine/pitchpine, oregon, or the rubbish "illigitimate"-mahoganys of the kind purveyed in model stores. If you do, sanding will lead to hundreds of small bumps and you don't want that
If working with oak, then by all means use bamboo
I am scribbling this from direct experience of using both
important to predrill all holes to effectively the same size as dowell, inject a decent quality wood glue into hole/coat dowell and gently whang home with a small hammer. Uwe clamps to hold stressed planks until glue hardens
