Author Topic: How good an engineer are you?  (Read 3486 times)
Tug
« on: September 27, 2008, 08:48:54 pm »
Ohh, I can see many older guys geting all very stiffly getting to their feet and here it comes......... Whwe we traimed a thread had to be cut by hand!
your the boy'os for me, A friend over here is in dire need of an 8mm bolt left hand thread, see theres the problem, (I dont have metric wheels so I am out, the harder it is the better its a kr*p saw and keeps stripping the bolts, and we all want wood for the comming [cold winter]
any one up to the job?  Tug
Junk is something you've kept for years and throw away three
 weeks before you need it.
bogstandard
Re: How good an engineer are you?
« Reply #1 on: September 28, 2008, 11:25:42 am »
I don't have a lathe up and running at the moment, otherwise it would be a simple job, but maybe this might solve your problem in the short term.
Seeing as it is a screw chewer, maybe you need a method of making more than one.
Try here
http://rdgtools.co.uk/acatalog/LEFT_HAND_METRIC_TAPS_AND_DIES.html
andrewh
« Reply #2 on: September 28, 2008, 12:14:40 pm »
I'm an EXTREMELY good engineer, noted both for quality and modesty
Dunno what the problem is with the saw - in the long run it would be better to solve this basic problem than keep replacing the screw
My first thought is to Google M8 LH threads - and Allthread do lengths of M8LH threaded rod.  Buying one of these gives you potentially dozens of whatever length you need, and they can be replaced with liltte grief - but you might need a few LH nuts to make it work (get some LH washers at the same time ;D)
http://www.toolfastdirect.co.uk/acatalog/Mild_Steel_All_Thread_Self_Colour_Left_Hand_Metri.html
They also (probably) do it in zinc plated, A2 or A4 stainless, etc
If this for any reason cannot work - there are lots of fastener suppliers who sell M8LH in any length, type etc.
If you need hard - you should go for cap-head (allen head) bolts or screws
Not knowing the exact application, I can't tell if any of these are workable, but they are available and not expensive
Hope it helps
andrew
Proteus
« Reply #3 on: September 28, 2008, 12:25:42 pm »
andrew
Any chance of some pictures of your work we all like to see examples of craftmanship and what we should stride for.
Proteus
David_S
« Reply #4 on: September 28, 2008, 01:16:50 pm »
andrew
Proteus
May the more relaxed among us simply stroll for better craftsmanship?  :)
Tug
« Reply #5 on: September 28, 2008, 02:01:52 pm »
John/Andrew, Thanks for the words
I was only asked, and for the minute brain went ded,  again
John I have some reversable washers one side left hand the other right hand,
cost a fortune at the time.  Tug
catengineman
« Reply #6 on: September 28, 2008, 04:25:00 pm »
Sorry to say but there are LH washers!  SPRING and ANTIRATTLE for said LH applications.
R,
andrewh
« Reply #7 on: September 29, 2008, 08:32:14 am »
Tug,
You probably gathered that people would like to help, and could possibly do so more if we had more info (and Pictures ;D)
Hope there are some glimmerings of the answer appearing.
Proteus - I was employing hyperbole, irony and modesty.
I was actually thinking along the lines of the definition of an engineer as "a person who can do well for a shilling what anyone can do for a pound"
If you use gas or electricity in the UK, or have landed at HK airport you have used my engineering, but I can only claim to have contributed in the team.
andrew
Page created in 0.273 seconds with 22 queries.
