i still think the top roof box idea is not rediculous-
yes it is gonna be tough getting the model up and down off the roof of the car into the water or into the workshop, but i still think the issue of the loading on the roof may not be so far off ...
i cant speak for the mondeo... but i had a laguna estate some years ago... i have a Thule roof box and Thule bars,
the thule luggage box would not contain a model 2m long but the box is basically only a huge vacuum forming, - but it is certificated to an 80 kg loading, so in theory 80 kg in a plastic bubble strapped to the roof is feasable and as far as the authorities are concerned it is feasable and safe, the box is TUV approved........
the box attatches to bars that go across the car... ( horizontal bars ) these then fix to feet that attatch to your car make/ model or via roof rails/ roof bars if the car has these fitted....
the horizontal Thule bars are certifcated to a higher loading still, but these attatch to the factory fit roof bars on the laguna car- renault claim these roof bars/ fixing points were good for over 100kg roof weight loading..
so the plastic box weighs a few kgs even when empty, the max permissable load in the box of 80 kg and then the horizintal bars......all this then attatches to the car roof via the roof rails or the roof rack fixing point... so a load potentially of 100kg on the car roof is 'do able'
my thoughts are - custom make a box to fit the boat into in a material of your choice,
chances are its not going to he rediculously tall, make it as low as possible so as to keep the centre of gravity as low as possible but make it fit your model ...,
the thule bars that fit to most makes of car are quick fixing types , they can be removed fairly quickly if required, the bars allow for all types of fitting to be added from boxes, to canoe carriers to cycle carries and the likes, all fix using a U shaped fixing and swing fixing, so place the U clamp round the bar and whatever is being carried so the U clamp could protrude through the bottom of the boat carry box , this is then placed on the bars and then the swing fixing is placed over the 2 'open ends' of the U fixing and are closed onto it, they grip and keep everything in place... tight and secure ...
as the box is not going to be as wide as the car place- down the centreline of the vehicle on the roof and take it steady.....
i took my thule box fully loaded along with a fully loaded car and trailer to spain and back with no problems.....those Thule patented U fixings fix and relase in seconds, once they're done they're tight.... they dont loosen during a journey either....
so i suggest contacting ford to see what the car roof points can safely carry and consider the roof option, Thule is expensive kit but safe and quality, a well made box in timber or maybe GRP could be a possability.....
the joy with a roof box is if made correctly this could be used on different cars just by changing thule foot pack feet to whatever make/ model of car you plan to use...so it would be interchangeable....
any idea what a boat that size would weigh ?
