Author Topic: fire boat help !!!!!!  (Read 2425 times)
wlr
« on: November 03, 2008, 03:49:50 pm »
can anybody help I am going to be building a fireboat like the old aerokits versions,but from a kingston mouldings hull. going to be the 46" hull.unlike the old aerokits single screw this will be a twin screw as per the prototype. now I have 2x mfa 850 motors spare does anybody think this is a good choice to power the model ????  any thoughts would be most welcome
Re: fire boat help !!!!!!
« Reply #1 on: November 03, 2008, 04:05:22 pm »
I have an 850 fitted in my Sea Queen, which is 46" long. It performs very well getting up on the plane with ease. So two should be most satisfactory.  :-))
Doug
Proteus
« Reply #2 on: November 03, 2008, 04:08:32 pm »
should be OK but build it as light as you can and use nicads, there are some on  http://modelfireboats.com/  that may help you, and there are some posts on this site if you search under fire boat.
Proteus
debssnal
« Reply #3 on: November 05, 2008, 06:49:03 pm »
Hi re your fireboat
Motors 2xTornado Thumper 4240 Brushless motor - 540 watt motor, 900 kv. @ £27.99 each
Link for motors  http://www.overlander.co.uk/categories/default.asp?cid=10&scid=82
ESC'S 2X
Programmable Brushless Car ESC XC60A Continue with BEC
Link for ESC'S  http://cgi.ebay.co.uk/Programmable-Brushless-Car-ESC-XC60A-Continue-with-BEC_W0QQitemZ260273684761QQihZ016QQcategoryZ34056QQtcZphotoQQcmdZViewItem
You can run on gel cell or nimh ok
You can use 4 bladed scale props ok
MFA 850 are power hungry and weigh 500g each
this brushless set up will give you a lot more power, aong running time
Kind regards
Alan
Page created in 0.562 seconds with 21 queries.
