Author Topic: miniature propshaft couplings...  (Read 3464 times)
das boot
« on: November 11, 2008, 08:33:21 pm »
Does anyone know if it’s at all possible to buy motor to shaft couplings to connect 380 size motors to a 1/16th diameter propshafts?
longshanks
Re: miniature propshaft couplings...
« Reply #1 on: November 11, 2008, 08:42:32 pm »
Hi Rich,
SHG do just what you want. I havent used them just happen to remember seeing them earlier today
http://www.shgmodels.com/acatalog/
Page 40
longshanks
wideawake
« Reply #2 on: November 11, 2008, 11:33:28 pm »
Hi Rich,
Page 40
longshanks
I bought just such an item from SHG myself at the show.  A simple UJ unit with interchangeable inserts so that you can match motor and propshaft diameters.
For a heavier duty version of the UJ see the Ripmax website.
Guy
Philipsparker
« Reply #3 on: November 12, 2008, 08:39:53 am »
If you aren't putting a lot of torque through the joint, simple rubber tube will do the job. Try fuel line from model aircraft suppliers like Howes.
Phil
andrewh
« Reply #4 on: November 12, 2008, 08:40:41 am »
Small bore silicone tubing is good for this type of coupling - strip the insulation off a 1 inch length of silicne wire, and use the insulation!
It even has helical "grip grooves" on the inside.
I don't think that there is anything that a 380 can do what would worry a tube coupling
If the propshaft is a little too small for comfortable grip inside the tube sleeve it with heatshrink, or a short section of sleeving from a smaller cable
cheap and quiet and effective - just like me :}
andrew
« Reply #5 on: November 12, 2008, 10:12:49 am »
And if the tube coupling starts to slip, roughen up the shaft surfaces and use a tiny drop of superglue!  :-))
andrewh
« Reply #6 on: November 12, 2008, 10:36:15 am »
I have been  known to slide a short sleeve of brass tube over the slipping end so that it increases the "grip" of the tube
My brass tubes come from salvaged radio aerials - they also make great punches by sharpening the ends and also rudder bearing tubes, etc.
andrew
it's the scottish upbringing
Bunkerbarge
« Reply #7 on: November 12, 2008, 10:48:31 am »
I used UV joints on the U-boat conversion to start with but didn't like them as they were not perfectly balanced and vibrated.  I cahnged to using the Robbe silicone tubes and they run beautifully smoothly now.
I put a spot of superglue on them to ensure they don't slip which can easily be removed with a craft knife and abrasives if you need to.  For this size of motor they are easily the best type of coupling.
das boot
« Reply #8 on: November 12, 2008, 03:24:30 pm »
Excellent...thank you gentlemen, much appreciated. I like the rubber tube idea (seeing as how it's free... :-))), got yards of brass tube laying about, got gallons of superglue as well...rubber tube sounds good!
Cheers guys,
