Author Topic: Hiding mast head light wiring.  (Read 8813 times)
RODDERS
« on: November 26, 2008, 12:45:10 pm »
Please forgive these naive Q.s!........ Havent built stuff for many years! I assume the mast(s) are hollow(brass,or maybe aly?) tube,allowingthe light wiring to run up inside?
      Rod
Re: Hiding mast head light wiring.
« Reply #1 on: November 26, 2008, 01:27:37 pm »
Why hide it as the full size ships dont.
RODDERS
« Reply #2 on: November 26, 2008, 04:05:21 pm »
Really? S'pose they must do,as they havent got hollow masts! If the wiring is small enuf dia it would be OK.
               Thank You .........Rod
gribeauval
« Reply #3 on: November 26, 2008, 04:32:39 pm »
Rod if you want very small diameter wires for lighting then go to your local £1 shop and buy a scart lead (usually about 1.5mts long). Strip it down and there you have lots of very thin wires all in different colours. Or use a USB cable, or a computer network cable, again lots of different colours in very thin wire.   8)
True Lifeboat Nutter!!
portside II
  • tugs at rest
« Reply #4 on: November 26, 2008, 06:38:53 pm »
Rod , if you want to hide the wires ,yes stuff them in a hollow mast .
If your mast is alloy or brass cut down on the wires by using the mast it's self as the negative supply .
If you want to use wood then why not run some thin brass wire up the mast for the feeds and then branch off where you want a lamp/led, paint the wire the same as the mast and it will nearly dissapear .
daz
RODDERS
« Reply #5 on: November 26, 2008, 08:04:09 pm »
All good ideas ! I'll have a think about which to use!
wideawake
« Reply #6 on: November 26, 2008, 08:24:11 pm »
....and if you need really thin stuff then don't use plastic covered wire but get some enamel covered either by buying or stripping an old transformer or similar.
HTH
Guy
norry
« Reply #7 on: November 26, 2008, 08:39:46 pm »
Or else make your mast out of a McDonalds McFlurry Spoon Handle...
portside II
  • tugs at rest
« Reply #8 on: November 26, 2008, 09:14:52 pm »
a visit to Mc Donalds makes your day boat mast {-)  {-)  :-)) .
daz
dan
« Reply #9 on: November 26, 2008, 10:13:45 pm »
hi Rod
what boat is the mast for and at what scale?
cheers, dan
Ghost in the shell
« Reply #10 on: November 26, 2008, 10:56:46 pm »
what I did with Gemini, my Graupner neptun, was run the wires down the bow and stern mast tubes, however the main mast was not hollow, so the wires had to go down the outside, to hide them, white electrical tape over a white mast
Go Nuclear!  you'll love it
« Reply #11 on: November 26, 2008, 11:22:54 pm »
I cut a slot in wooden mast on Jan's Puffer ..... very, very tricky!
I also used transformer wire.
Umi_Ryuzuki
« Reply #12 on: November 27, 2008, 05:37:43 am »
Some more pictures of mast wiring.
The brass mast is grounded, two wires run up the outside disguised
as conduit. One for the running lamp, the other for the towing lamps.
The mast can be removed simply by lifting it out out of its mounting hole, and
a deans plug disconnects the two hot leads. As shown on this Tito Neri build.
Switches can be hidden behind doors
or in left plain site, shown here disguised as winch controls.
Bunkerbarge
« Reply #13 on: December 04, 2008, 05:53:57 pm »
Umi,
Where do you get hold of those dean's connectors?  They are exactly what I want for a couple of locations on my current build as well as some of my older models.
portside II
  • tugs at rest
Bunkerbarge
« Reply #15 on: December 05, 2008, 02:52:17 am »
Thanks for the links Daz, they are just the sort of thing I'm after, especially the micro ones.  Where's that credit card gone!
Umi_Ryuzuki
« Reply #16 on: December 05, 2008, 06:21:02 am »
Umi_Ryuzuki
Bunkerbarge
« Reply #18 on: December 06, 2008, 05:45:59 pm »
I did see them, very neat.  I eventually went for some small four pin items, not Deans but very similar so I'll have a play with them and if I'm not happy go for the three pin Deans type.
Page created in 0.2 seconds with 18 queries.
