Author Topic: Models by Design?  (Read 22007 times)
debssnal
Re: Models by Design?
« Reply #25 on: December 15, 2008, 09:21:27 pm »
they would go better with brushless
kind regards
Alan
bwmarks
« Reply #26 on: December 23, 2008, 02:54:23 am »
I just received 2 hull kits from Andy. They are excellent quality and survived the Atlantic crossing with no problems. Thanks for all the advice and now I can highly recommend Models by Design.
Brian
debssnal
« Reply #27 on: January 18, 2009, 06:45:59 pm »
Hi Brian,
           How are you geting on with your boats.Got one made yet ??????
Lets see some pic's when you can
kind regards
Alan
bwmarks
« Reply #28 on: January 19, 2009, 12:10:37 am »
Hello, no progress yet except some photos of the mouldings...I need to finish the Light Ship "RELIEF" before I start another project...
tugboyben
« Reply #29 on: February 23, 2009, 07:02:59 am »
hi all
received my new boat from andy at models by design on friday 1/16 scale sf 33 fishing boat WOW super bit of kit very happy :} will be makeing a good stand today ready for the build
regards jason
chipchase
« Reply #30 on: February 24, 2009, 07:13:10 am »
Hi Jason
 I purchased a hull and a set of plans from Models by Design December 08. The hull was excellent quality; I will certainly use them again.
good luck with the build.
tugboyben
« Reply #31 on: February 24, 2009, 08:54:17 pm »
hi chipchase
i will be strating at the weekend get the prop fitted i have a 12volt decaprem motor so it will be haveing a 70mm brass prop i will be makeing my own brass rudder i will post pictures as i go on
regards jason :-))
chipchase
« Reply #32 on: February 24, 2009, 11:26:12 pm »
Jason that’s a big prop for that boat?
tugboyben
« Reply #33 on: March 19, 2009, 08:35:54 pm »
hi all
started the cygnus sf33 fishing boat today got the prop motor & shaft in today a few pictures for you to look at i will have more soon
best regads jason
« Reply #34 on: March 19, 2009, 08:40:57 pm »
Do you think you should have gone for a bigger prop  ok2
tugboyben
« Reply #35 on: March 19, 2009, 08:48:53 pm »
hi dickyd
i was putting a 70mm but when for a 60mm the 70mm was a little bit big   {-) {-)
...best regards jason....
tugboyben
« Reply #36 on: April 05, 2009, 09:43:33 pm »
HI ALL
a more work on the fishing boat today
best regards jason
debssnal
« Reply #37 on: April 07, 2009, 08:13:18 pm »
Hi Jason,looking good.Keep the pic's coming
kind regards
Alan
The long Build
« Reply #38 on: April 07, 2009, 10:07:48 pm »
Looking Good ,
 Just trying to work out what the engine is mounted on to the hull ??
tugboyben
« Reply #39 on: April 08, 2009, 08:10:48 am »
hi long build
Thanks the motor is a 12volt decaprem with a 60mm prop more pictures soon hope to test down the pond at the weekend
kind regards jason
The long Build
« Reply #40 on: April 09, 2009, 12:30:03 am »
That as well , but how is it mounted to the hull.
portside II
  • tugs at rest
« Reply #41 on: April 09, 2009, 12:23:39 pm »
Looks like a piece of ply bonded to the keel and the motor mount screwed in place .
daz
tugboyben
« Reply #42 on: April 09, 2009, 04:13:08 pm »
hi portside11 & the long build
the motor mount is fibre borad it is just like plasticard when the filler was set some fibre glass tissue & resin with blue pigment all a round the mounts hope it helps some pictures
kind regards jason
tugboyben
« Reply #43 on: April 09, 2009, 08:40:39 pm »
hi all
its not fibre board i used in the fishing boat the name for it is 10mm foam x
best regards jason
Faraday's Cage
  • Change is inevitable, except from a drinks machine
« Reply #44 on: June 10, 2009, 07:47:04 pm »
Just a couple of pictures from my completed MBD fishing boat. I'm really pleased with the final model and its been a joy to build.
FC
Guy Bagley
« Reply #45 on: July 02, 2009, 12:07:01 pm »
lovely model FC !
are the fenders the ones from cap maquettes ?- in silicon ? if so be warned they in time degrade and split and come off the top section, ( plus being solid silicon they sink  ! )
 i had quite a few of these on my fishing boat, all of them split and cracked as the silicon aged.... takes about 2  years for them to go 'bad'
i replaced 'em with the resin ones from macs mouldings !
Faraday's Cage
« Reply #46 on: July 02, 2009, 03:06:07 pm »
Hi Guy, yes they are and thanks for the warning. That's quite disappointing as they're not cheap to buy.
I'll keep my eye on them.
FC
Guy Bagley
« Reply #47 on: July 02, 2009, 03:43:11 pm »
i have about £40 worth of them on the bottom of our lake !!!!!
« Reply #48 on: July 03, 2009, 09:32:12 pm »
I'll be around with my scuba gear Guy  {-) {-)
Langsford
« Reply #49 on: July 04, 2009, 12:30:43 pm »
Has anyone built their HMS BULLDOG? Would be pleased to hear reports and see any pics.
Cheers, John
Page created in 1.087 seconds with 22 queries.
