hi,she has a zz4 engine,its actually a chevy crate motor,a 385,she is rated at about 400bhp,holley 750 double pumper carb,a tremec 5 speed manual gearbox,new 4 pot ssbc calipers,vented and grooved discs all round,new copper brake lines,uprated suspension,chassis joiners,all new bushes,she has probably had over 20k put into her ,,she goes like hell
)all of the work was carried out in 2006,listed below is a full spec if anyone is interested,,daz
New GM Fast Burn 385 V8 crate motor ( 385 h.p. / 385 lb./ft. torque )
New Holley 750 cfm. Double pumper carb , with Speed Flow braided hoses and aero couplings and fuel meter.
New fuel tank and sender unit ; custom made copper fuel lines ; new Holley mechanical fuel pump.
New Ceramic coated headers by Doug , linked to Flowmaster American Thunder 2.5 inch exhaust , with Flowmaster s/steel tips
New Tremec TKO 600 5- speed gearbox – just run in.
New McLeod 168 tooth flywheel
New McLeod 11 ½ inch clutch
New Inland Empire driveshaft
New BeCool aluminium rad. / BeCool hexagonal rad cap / BeCool twin 11`` electric fans with thermostats / Moroso aluminium recirculating can.
New SSBC 4 wheel disc brake conversion with red calipers. ( 11 in. drilled and slotted discs ) . New master cylinder and servo , with balancing valve. Custom made copper brake lines.
Lokar handbrake conversion – now located on transmission tunnel.
Front suspension : Hotchkis springs ; Edelbrock Performer shocks ; Fatman Fabrications tubular wishbones with PST all polyurethane bushings and PST tie rod ends ; Hotchkis 1 1/8in front swaybar.
Rear suspension : New OER multileaf springs ; Monroe air shocks ; Hotchkis 7/8in rear swaybar ; Competition Engineering Slide-a-Link adjustable traction bars ; Competition Engineering subframe connectors with new polyurethane subframe bushings.
