Hello,
You may have seen me on another forum. I am new to boat modeling but not building. I have ask this question elsewhere but I did not exactly understand how the procedure would work or turn out for me.
Attached..... I hope this boat owner does not care..... I have attached a photo, and this is dthe
Basic color scheme I want to achive. I have looked at many photos on the forums of boats under construction. I understand the glassing/sanding/ and finishing the hull, inside and out.
The decking and the cabin sides I want to stain, seal, and clear coat, and from a past answer, and photos, assemblygluing of the decking and cabin were done before glassing and applying resin. I just don't understand how I can achive the look I want since stain will not soak in with resin applied. It also seems gluing would not be as solid with finish on it. It was previously mentioned about painting and staining and just being careful etc. For me..... I don't know if I can do this that well.
Does someone have a "step procedure" to help me understand?
Thanks,
sloboat
