Pages: 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 ... 25   Go Down
Author Topic: The infamous Motorflote ( Motorflotte ) push tug...  (Read 294548 times)
Re: The infamous Motorflote push tug...
« Reply #150 on: March 02, 2015, 03:00:33 pm »
That's what you pay me for!   :kiss:
U-33
  • K-157 Vepr. Akula-11
« Reply #151 on: March 02, 2015, 03:35:40 pm »
Oh well, in that case...you're fired!
« Reply #152 on: March 02, 2015, 04:20:53 pm »
... not for the first time!  <:(
inertia
« Reply #153 on: March 02, 2015, 04:22:30 pm »
Start with the 385; the 400 Race will almost certainly be too fast, even on 6 cells. If you do decide to go mad later on then the 400 will fit the same mount and coupling.
"RA"?
Dave M
inertia
« Reply #154 on: March 02, 2015, 04:25:09 pm »
Gorrit.
Rheumatoid arthritis. Not good for an active modeller.
DM
U-33
« Reply #155 on: March 02, 2015, 04:33:53 pm »
Thanks Dave...I sorta figured that may be the one to go for. Speed makes no difference to a Motorflote, if you attempt to go fast they just start to wallow. Not a pretty sight...
RA...correct, not good for anybody. On a good day I can do most of the things that I used to be able to do...on a bad day I have trouble rolling a smoke.
Subculture
    • Dive-in to Model submarines
« Reply #156 on: March 02, 2015, 05:48:45 pm »
Don't think a 380/385 motor will have enough torque to pull a 35mm prop efficiently direct drive.
hmsantrim
« Reply #157 on: March 02, 2015, 06:13:02 pm »
Probably float a couple of feet above the mattress  %%
If  there were four other people in the room though Rich could have a "High Five"... {-)
frank
U-33
« Reply #158 on: March 02, 2015, 06:43:51 pm »
I have trouble with a High 1, let alone a High 5...
« Reply #159 on: March 03, 2015, 09:13:07 am »
It's been the normal drive on Revell Snowberrys for ever, and works well.  Usually the motor is on about half its rated max voltage.  Having said that, the original Springers (and this was originally going to be based on a springer hull)were normally powered by a 540.
U-33
« Reply #160 on: March 03, 2015, 09:27:14 am »
The Motorflote is completely flat fronted, at least the Springer does have a more rounded bow. A Springer does try and get up on the plane, a Motorflote will just start to porpoise if power is increased, the porpoising will just get worse the faster you try and go with it.
I don't think there's room to get a bigger motor in, I'll know for sure when the kit arrives later this week...if there is a chance of squeezing one of Mr Action's 550's in, then I will, but looking at the drawings it will be tight. The only other choice is to go brushless, I do have a brushless motor that Andy recommended, c/w the matching esc and a lipo, so I'll check that out when the kit arrives.
Pic shows size comparision between brushed and brushless set ups.
Subculture
« Reply #161 on: March 03, 2015, 09:44:58 am »
The 700kv brushless motor will work very well. Won't even work up a sweat on 2s and you can easily go to 3s if you want a bit more grunt.
U-33
« Reply #162 on: March 03, 2015, 09:50:14 am »
Another difference between a Springer and the Motorflote is the size..a Springer is 18'' long, a Motorflote is barely 12'' long, but with the aquadynamics of a pair of house bricks taped together.
That brushless set up is gaining in points over a conventional brushed set up, methinks...
U-33
« Reply #163 on: March 04, 2015, 01:06:45 pm »
Just had the good news from the lovely Debbie at Models By Design...the Motorflote kit is all cut out and in the post.
The crew signed on yesterday...he's known as George. Handsome devil...bears a distinct resemblance to a certain tv Doctor, I'm told.
hmsantrim
« Reply #164 on: March 04, 2015, 01:52:01 pm »
hi Rich.
 So!!  if there are any Gremlins in the engine room will "George" fix em with his sonic screwdriver.... {-) {-) {-)
 Frank
U-33
« Reply #165 on: March 04, 2015, 02:04:28 pm »
There was an original George, he's now the official team mascot for She Devil Racing...he has his own personal chair in the trailer, and is responsible for keeping law and order among the crew.
This  is George number...eleven, I think. It's a long story, Frank...
U-33
« Reply #166 on: March 05, 2015, 02:08:04 pm »
A package has just arrived from Models By Design containing...a flat pack Motorflote.  That's something you don't see every day... ;D
« Reply #167 on: March 05, 2015, 02:19:39 pm »
Are you using square section abs on each internal angle of the
hull boxes Rich?
U-33
« Reply #168 on: March 05, 2015, 02:25:04 pm »
Oh yes Ned...I bought a large selection of various sized square section stryene strip especially for that purpose.
U-33
« Reply #169 on: March 05, 2015, 04:08:53 pm »
I plan to reinforce every join in the whole boat...belt n' braces.
U-33
« Reply #170 on: March 06, 2015, 01:09:32 pm »
Fingers and hands fully operational today for a change, so I've made a start today on assembling the kit...so far, so good. Everything fits where it should, and it's going together well.
Using a rotary workstand to work on is a great help, it allows me to work on one, then the other, just by swivelling the stand around...brilliant idea, thanks to my mate Ian (IanPAL on here) for loaning it to me.
Time to tidy the bedroom up now, the ladyfriend is coming round later, so Motorflote construction is temporarily halted...
U-33
« Reply #171 on: March 06, 2015, 01:41:57 pm »
Last bit for today...made the steering nozzle support plate, just taped in position for now.
U-33
« Reply #172 on: March 07, 2015, 11:33:18 am »
Oh, meant to add...in the photos above, the motor ISN'T a Race 400, it's an ACTion 385, I 'borrowed' the torque ring from the 400.
Fitted the bow panel this morning...and yes, I know there's a slight discrepancy in the height of the left hand upright strengthening strip. Luckily, it won't show and it won't affect anything.
Subculture
« Reply #173 on: March 07, 2015, 08:24:04 pm »
A suggestion you can pass on with this kit. If it's going to be CNC routed, then it would be easy to include tabs and indents so that the parts clip together and self jig. That would simplify construction considerably.
mrzippy
« Reply #174 on: March 07, 2015, 11:27:21 pm »
Err? not sure what's going on here guys ??
I am following this thread with great interest - having built the original wooden Motorflote many years ago.
Looking at Andy's (Models by Design) Motorflote mock up at the Ellesmere Port Show today -
the kit includes the necessary bulkheads and sub frames required for easy assembly, all beautifully CNC routed.
I am guessing Richard, because of his dexterity problem, is building the model by his own belt and braces methods
employing box section plastic in place of the kits parts.
The MBD kit should make an easy build 'straight out of the box' as supplied.  Paul
Pages: 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 ... 25   Go Up
Page created in 0.166 seconds with 18 queries.
