Author Topic: SEA SHEPHERD PLAN  (Read 5890 times)
Workboat
SEA SHEPHERD PLAN
« on: February 06, 2009, 01:30:56 pm »
Hi every one thought I would buy feb model boats to get the plans on looking at them more closely I find there to be several discrepancy's that don't add up mainly the numbers on the bulkhead profiles don't measure the same as the ones on the side elevation,and the shape off bulkheads at the bow, may be its just me anybody else have any views or ideas on this plan ,cheers Dave
John W E
  • I see no ships !!
Re: SEA SHEPHERD PLAN
« Reply #1 on: February 06, 2009, 03:48:02 pm »
Hi Workboat
On the body plan the numbers for the ribs on the left hand side are supposed to go 6-7-8-8/1/2-9/9/1/2/10 and not 5/6/7/8/1/2
john
bluebird
Knowledge begins with respect
« Reply #2 on: February 06, 2009, 03:57:35 pm »
Was that supposed to read 6-7-8-81/2-9-91/2-10 and not 5-6-7-81/2 John ?
John W E
  • I see no ships !!
« Reply #3 on: February 06, 2009, 03:58:58 pm »
« Reply #4 on: February 06, 2009, 03:59:50 pm »
Back to bed then. :-))
Workboat
« Reply #5 on: February 06, 2009, 08:46:01 pm »
Hi guys thanks for that bluebird thought that was the case just wondering now if this plan is worth using or is their other things wrong with it what do you think of the shape of the first 3 bulkheads at the bow do they look  right cheers Dave.
John W E
  • I see no ships !!
« Reply #6 on: February 06, 2009, 08:50:45 pm »
hi there
yes, the first three frames look correct  :-))
this does look as though its been designed for a steel welded hull - on the original vessel.   So, it therefore tends to have flat sections at the bow.
This particular hull would lend itself greatly to a 'flat plywood construction'.
aye
john e
bluebird  :-))
John W E
  • I see no ships !!
« Reply #7 on: February 06, 2009, 08:55:50 pm »
Guess what Dicky  :-)) - I found the ½½½½½½½½½½½½'s
½½½½½½½½½½½½½½½½½½½½½½½½½½
½½½½½
½½½½½½½½½½½½½½½½½½½½½½½      ½½½
½½½½½
½½½½½
½½½½½
½½½½½
½½½½½
½½½½½
½½½½½
½½½½½
½½½½½
½½½½½
½½½½½
½½½½½½½½½½
½½½½½
½½½½½
½½½½½
½½½½½
½½½½½
½½½½½
½½½½½½½½½½
½½½½½½½½½½½½
½½½½½½½½½½½½½
½½½½½½½½½½½½½
½½½½½
½½½½½
½½½½½
½½½½½
½½½½½
½½½½½
½½½½½
½½½½½
½½½½½
½½½½½
½½½½½
½½½½½
½½½½½½½½½½
½½½½½
½½½½½
½½½½½
½½½½½
½½½½½
½½½½½
½½½½½½½½½½
« Reply #8 on: February 06, 2009, 09:10:15 pm »
I knew where they were all the time, just didn't want to show you up.!!
½½½½½½½½½½½½½½½½½½½½½½½½½½½½½½½½½½½  :P
japottinger
« Reply #9 on: April 30, 2009, 08:41:00 pm »
Possibly I do understand the question , and not sure what was the problem referred to by the original posting, as far as I can see the numbers on the body plan stations  on my plan match up to those noted on the longitudinal views.
Can you possibly explain further what is the problem?
Jim
japottinger
« Reply #10 on: April 30, 2009, 08:43:17 pm »
PS the shape of the bows etc was taken from original designs, and verified by the responsible naval architect concerned.
japottinger
« Reply #11 on: May 01, 2009, 01:52:11 pm »
Re above looking more closely at the published version of the plan I can see that the notation 81/2 has been missed on the body plans although the actual section is there. Naturally I am concerned about any errors. My original plan is "scanned" by a PC scanning process by another agency used by Model Boats, and the copy is sent to me for proof reading prior to publication, not unknown for a checker to make an error, greater number of copies greater chance of mistake!
Would be interested in any models built to the plan.
Page created in 0.05 seconds with 21 queries.
