Author Topic: How do you siimulate rivets on a wood hull  (Read 2756 times)
pmgargan
« on: February 13, 2009, 12:42:03 am »
I have tried several methods of simulating rivets , the one that worked was using a 'stitch' marker wheel on the back of card . That worked but on window frames . Another was using drops of white glue . Again on window frames . More difficult to get right . and if you don't get it right , it looks terrible.
         My problem is its a hull about 25" long . has riveted hull AND superstructure. Plastic card is not suitable , litho plate would sink the boat and pin heads are too large . Besides the thought of cutting the heads off 2000 odd pins is mind boggling. spacing of rivets is about 3/16" to 1/4". NOT flush rivets , the good old fashioned round head type.
         Any suggestions welcomed except rude ones !
dreadnought72
Re: How do you siimulate rivets on a wood hull
« Reply #1 on: February 13, 2009, 08:57:10 am »
If the stitch marker works ok on paper/card, then you could plate up the hull in cartridge paper (rivets added before sticking them on) and, once done, apply coats of G4 resin.
The G4/paper finish is as tough as old boots.
Andy
MikeK
  • Utter Bloody Chaos !!
« Reply #2 on: February 13, 2009, 10:40:06 am »
Same thing applies to plates made up from Plasticard sufficiently thin to make impressions with the wheel.
Page created in 0.265 seconds with 21 queries.
