Author Topic: Plank on Frame  (Read 2772 times)
CERES
  • Proud to be a part of the Model Boat Mayhem Forum.
Plank on Frame
« on: September 28, 2006, 07:43:08 pm »
 :) :) :)Hello,
I would be interested to know what others do or use to stop Cyno sticking to ones fingers when applying the outer skin. Light pinning could be used but you never get a prope match of filler especially Mahogany strip.
I have not been around for awhile but now I am building again. ;) ;) ;)
anmo
  • That's unpossible!
Re: Plank on Frame
« Reply #1 on: September 28, 2006, 08:44:41 pm »
A tricky question. I make sure that I only hold down the plank I'm fixing with the tip of a fingernail. It's easier than it sounds once you get the hang of it, and it's quite easy to twist the nail off the plank once the glue has hardened. Easier to sand dried glue from a nail than a fingertip as well.
caution, may contain traces of nuts .....
Re: Plank on Frame
« Reply #2 on: September 29, 2006, 12:42:46 pm »
When cyano was first introduced, a range of plastic tools was sold (pliers, tweezers, pointers etc).  They were made of a type of plastic that superglue would not stick to.  I dont think they lasted commercially as most moddelers got the idea and found plastic items that could be used just as well.  Just find something that the superglue wont stick to, and hold the plank in place with that.
Re: Plank on Frame
« Reply #3 on: September 29, 2006, 01:48:47 pm »
Is it the same fingernail as in your Avatar Anmo, or did you try to pick your nose with cyano still on the nail?  ;)
White Ensign
  • Limits must be limited!
Re: Plank on Frame
« Reply #4 on: September 29, 2006, 01:55:24 pm »
Ceres, I use to fix planks with small needles, before I glue them. The only method I know as I have already "lost" some fingertips...  ;)
Jörg
When God created planet earth, he made it with 75% of water. Bet he had the modelboaters on his mind!
anmo
Re: Plank on Frame
« Reply #5 on: September 29, 2006, 03:41:43 pm »
No, I'm left-handed.
Page created in 0.02 seconds with 22 queries.
