Author Topic: fwd, rev & throttle control  (Read 13214 times)
bogstandard
Re: fwd, rev & throttle control
« Reply #25 on: May 07, 2009, 01:19:30 am »
With
Has anyone had problems with servo wear when driving the Stephenson's valve gear. On my Stuart D10, I've noticed some oscillating back-force from the valve gear if I don't clamp the forward / reversing arm as the engine runs. I would imagine that the servo gears and motor might wear under this action.
Ian.
I have just made up a slip joint that should eradicate the up and down movement of the lever. It works by having just enough friction to hold the lever steady while in normal running, but when an input from a servo is given, the joint slides to its new position and carries on.
http://madmodder.net/index.php?topic=1054.msg9084#msg9084
The lever has yet to have the holes drilling into it, so that a servo can be connected for operation. That is todays job.
Bogs
Bernhard
« Reply #26 on: May 07, 2009, 12:52:45 pm »
Hi..........what a nice engine,,,,,,,,,,and What a great job you have don to bring it back to life,,,,,,,,first class
regards Bernhard
AlexC
« Reply #27 on: May 07, 2009, 12:59:59 pm »
Hi Guys,
I thought it might be of help to add a few notes about setting up Stephensons' link equipped engines as it appears that some of you are having issues with this.
Die Slip
One of the most common mistakes made when using/setting up Stephensons' link valve gear is to move the link from one extreme of the link slot to the other when going from forwards to reverse.
Stephensons' link gear, especially on marine engines where the eccentric rods are relatively short, suffers far more from a phenomenon termed ‘DIE SLIP’ where the’ DIE BLOCK’ connecting the ‘VALVE SPINDLE’ to the ‘SLOTTED LINK’ slides sideways in the link slot rather than pushing/pulling the ‘VALVE SPINDLE’.
This occurs because of the extreme angularity imposed on the ‘LINK’ as one eccentric moves towards the link whilst the other is moving away.
This effect is much more severe on a marine type engine where the lengths of the eccentric rods is short, thus making the angular variations between the forward and reverse eccentric rods, and hence the angularity of the ‘LINK’  more severe which in turn presents the 'DIE' to the slot at a much more acute angle… resulting in a sideways movement of the 'DIE' in the 'LINK'.
On a steam locomotive this angularity problem is overcome, to some degree, by fitting the eccentrics to a more rearward axle, often the most rearward, which gives the maximum possible length for the eccentric rods, which in turn reduces the angular variation, but even here some DIE SLIP still occurs.
The way to overcome this is to not use the full length of the available ‘LINK SLOT’ but to restrict the movement to around 90% to 95% of the available slot length in either direction about the centre of the ‘LINK’
This will allow a short length of slot to accommodate the inevitable ‘DIE SLIP’
A properly designed ‘STEPHENSON’S LINK’ gear will have been designed to work at this slot position.
If the full length of slot is used then any ‘DIE SLIP’ will cause the ‘DIE’ to hit the end of the slot as the engine rotates with the result that the whole link assembly, and any connecting levers, will have no option but to move in sympathy thus leading to the perceived, and unwanted, lever movement.
DIE SLIP occurs when the angularity of the LINK relative to the DIE BLOCK is such that the DIE BLOCK will slide sideways in the link arm slot rather than move the VALVE stem in or out.
LOCKING the forward reverse mechanism at the extremes of slot travel, with no available slot length left for ‘DIE SLIP’ will only cause long term damage to the valve operating stem/bearing, and to the sliding die.
It is more usual to set the FULL FORWARDS and FULL REVERSE positions of the valve gear to leave some SLIP space available at the extremes of the LINK SLOT to allow for this DIE SLIP. I.E +/- 90% of available travel.
DIE SLIP is much more of an issue with marine engines since the eccentric rods are generally much shorter than on a locomotive and hence have greater angularity problems to overcome.
Try setting your full forwards and full reverse positions to around 90% of the available slot length in either direction and I think you will find a lot of the perceived problems become much less of an issue.
You will still need to use some form of servo buffering, since there will always be some frictional forces to deal with, but these will not be anything like as extreme as the DIE BOTTOMING out in the LINK.
John,
Lovely work, as always, on the refurbish job…. Is that the ‘MARCHER’ or the ‘BORDERER’ engine, it’s difficult to tell which from the pics, but I suspect the ‘MARCHER’.
Best regards to all. :-)) :-))
AlexC
bogstandard
« Reply #28 on: May 07, 2009, 10:51:44 pm »
It is the Marcher, but the bottom end looks like it was made by a master model engineer, and the top end by an amateur. I am trying to put right all the wrongs without having to make too many new parts.
I have most of the plans, but no instructions. So I am timing it by the seat of my pants, thru experiences of similar engines. It runs OK, but would just like to get it spot on, it is nearly there just not quite if you know what I mean. Or if anyone has the timing setup, a look at it would be gratefully appreciated.
wideawake
« Reply #29 on: May 08, 2009, 09:47:09 am »
Hi John
I've got the original ME construction articles by John Bertinat for both Marcher and Borderer.   If they'd be useful I could get them copied for you.
HTH
Guy
