Author Topic: Displacement Lubricator for TVR1A Engine  (Read 6768 times)
monarch
« on: February 14, 2009, 10:18:45 pm »
Can someone recommend a supplier for a good quality displacement lubricator that's suitable for the Graham TVR1A engine.
I understand that the small hole size inside the device is important, so that the right amount of oil is delivered.
Re: Displacement Lubricator for TVR1A Engine
« Reply #1 on: February 15, 2009, 12:57:38 am »
Monarch......this is a link to Paddleducks & to a Winfried Niggle WEB site......he manufactures beautiful glass tubed steam lubricators...the beauty is you can see both the steam condensate & steam oil levels....& never fear of running out of oil...his latest versions even have a blow down needle valve in the base :-))...Derek
 http://www.paddleducks.co.uk/smf/index.php?action=links;sa=visit;id=48
I have the ...following [400-110] version & @ EURO 28 is great value........only issue was the registered post from Germany to Australia was nearly as expensive...Winfired is also a great person to communicate &  deal with
http://www.modellbau-niggel.de/Verdraengungsoeler-mit-Glaszylinder-400-110-i54.html
Look under Oler.....his 410-111 is the pick of the bunch....NO not a paid advertisement....am not related to the manufacturer...just a very happy customer     {-)
In PD's...we term the Company as......A German manufacturer of quality steam fittings & accessories for model steam projects
Bernhard
« Reply #2 on: February 15, 2009, 07:32:37 am »
Hi...............i have 4 Graham engines.....and i have used this on them all........a great lubricator it is,,,,,,
http://cgi.ebay.com/Lubricator-Displacement-Type-to-1-bore-engine_W0QQitemZ270272521705QQihZ017QQcategoryZ2594QQcmdZViewItemQQ_trksidZp1742.m153.l1262
if..rember to get the littel T with and a nippel--
bogstandard
« Reply #3 on: February 15, 2009, 09:52:02 am »
Monarch,
Be rather careful with your choice.
If you haven't got threading or machining equipment, you might find yourself struggling to get one to fit correctly or easily, unless you fit it into the pressure line itself. In which case, make sure you get the fittings to fit your pipe size.
US threads will most probably be a UNF or UNC thread or tapered derivative of either, UK will almost certainly be ME threads, and mainland European will be metric.
The hole size isn't too critical as long as there is lube going into the engine. A lot of people actually over lube the engine unnecessarily, and all it does is cover the engine in oil, and fills up the condenser much too quickly with unused oil.
kno3
« Reply #4 on: February 15, 2009, 10:18:05 am »
I would also recommend an adjustable oiler with valve. I have the Niggel oilers too, which Derek suggested, and they are very good. Besides, they come with fittings that fit the Graham engine (4mm pipe).
« Reply #5 on: February 15, 2009, 11:14:23 am »
Gents..... the basis of my recommendation of........ '410-111' is the pick of the bunch  is that it is a fixed orifice.....kno3 & bogstandard most correctly question the actual function.....ie.,  of the ratio of steam oil to steam passage........ <:( <:(....steam oil is not cheap.......my JMC3H is also not without cost.....so I am happy with my fixed flow of the 400-100 "OLIER"  O0....Derek
steamboatmodel
« Reply #6 on: February 15, 2009, 04:21:31 pm »
If you have the equipment you could make your own.
gerald
monarch
« Reply #7 on: February 15, 2009, 09:00:43 pm »
Hi all
Thanks for all the good advise on oilers, I am going for the Niggel 400-110 but don't understand a single word of German and so find ordering difficult, can anyone help or has 2 for sale?
« Reply #9 on: February 16, 2009, 05:10:26 am »
Monarch........initially I translated my enquiry into German........but Winfried 'types' in fluent English & was a pleasure purchasing from him....the quality of the product is also first class.....just watch out for the German postage costs >>:-( ...from memory actual postage was by DHL....Derek
kno3
« Reply #10 on: February 16, 2009, 08:59:57 am »
Hi all
Send him an E-Mail in English with your request, using the form at this link:
http://www.modellbau-niggel.de/Kontakt-e150.html
And, by the way, I wouldn't get the 400 110 if I were you, but one of those with a valve, like 400 112 & 400 113:
http://www.modellbau-niggel.de/Verdraengungsoeler-l203.html
Page created in 0.017 seconds with 19 queries.
