Author Topic: Johnson 888 motor?!  (Read 3605 times)
flybobby
Johnson 888 motor?!
« on: September 28, 2006, 10:32:37 pm »
Anyone used or have any info on this motor?  I have one kicking around my workshop, but have never used it.  I would like to know if it will run ok on 12v?
Any info appreciated  ;)
Re: Johnson 888 motor?!
« Reply #1 on: September 28, 2006, 10:49:40 pm »
They are rated at 12 volts, but even on free running in a g/box they get hot.
They run on 9000 rpm at 12 volts, but the stall current is horrendous.
Do what I did with mine, either run on 6 volts or use as ballast in the bin.
I did the latter.
flybobby
« Reply #2 on: September 28, 2006, 10:54:31 pm »
I did the latter.
Could you recommend a decent 12v motor?  Low drain would be nice ;)
Merce
« Reply #3 on: August 29, 2012, 09:26:51 am »
If anyone has a Johnson 888 motor I would be pleased to buy it as a direct replacement for one which has given up the ghost! Thank you.
regiment
« Reply #4 on: August 29, 2012, 12:40:54 pm »
i was given two motors some time ago no name but a lot of numbers.. rs445paa15200r made in china gose ok on 12 volt has a metal sleeve on  which can be moved   any ideas
Page created in 0.107 seconds with 23 queries.
