Author Topic: POP-POP TUTT TUTT  (Read 12895 times)
Bernhard
POP-POP TUTT TUTT
« on: February 20, 2009, 06:48:24 pm »
Hi,,,,,,,,,It Dont have to cost alot to be fun to play with,Steam ?,,,,,,and can easy be made to work with  a small rc,,,,,,,,,,,and so it can allso have a long working time.i did the boiler and the small enginen,,,and the wood rowboat,i did age it a littel..run on rasp oile
http://www.youtube.com/watch?v=9oq6RZUkmMI
Regards Bernhard
Bunkerbarge
Re: POP-POP TUTT TUTT
« Reply #1 on: February 20, 2009, 11:06:34 pm »
What a lovely little model Bernard.  What is the propulsion system?  How big is it and where on earth did you fit the electronics bits in?
Another very nicely weathered model as well.  I'm looking forward to a shot on the water of it.
andyn
« Reply #2 on: February 21, 2009, 12:04:35 am »
It's one of them PopPopPopPopPopPopPopPop thingys BB
Looking good :-))
Bernhard
« Reply #3 on: February 21, 2009, 07:10:21 am »
Thanks.........yes...........it is one of the pop pop..engines?........
i have not yet made the rc,,,,it will be under the seat ,,just to the rudder.......i think from one of the small toy car or so..................i did use the smallest of them,in the photo
Bunkerbarge
« Reply #4 on: February 21, 2009, 07:44:13 am »
Brilliant job, thanks for the pictures.
tonyH
« Reply #5 on: February 21, 2009, 05:41:06 pm »
Superb model Bernhard, just the sort of thing for bath-time!
Tony
craftysod
« Reply #6 on: February 21, 2009, 08:02:51 pm »
Is there no stopping the detail this man puts into his boats,lovely work  :-))
Wish i could find the bits an pieces (oil cans etc) for my boats
Mark
Bernhard
« Reply #7 on: February 21, 2009, 08:14:21 pm »
kno3
« Reply #8 on: February 21, 2009, 11:55:26 pm »
Very nice!
Bernhard
« Reply #9 on: February 26, 2009, 11:24:55 am »
Hi,,,,,,,,Got a littel fire door to the pop pop boiler........great castning and polich ready to use,,,,,
http://www.tracksidedetails.com/parts201-220/201-210.html
regards Bernhard
Bernhard
« Reply #10 on: July 18, 2009, 10:01:53 am »
gondolier88
  • www.coniston-regatta.co.uk
    • Coniston Regatta
« Reply #11 on: July 18, 2009, 12:20:27 pm »
Hi Bernhard,
Fantastic idea!!! What have you used for the boiler casing- it looks like a drinks can to me?
Greg
Bernhard
« Reply #12 on: July 18, 2009, 03:34:09 pm »
hi...oh yes that what it is a small sodapop can,,,,,,,,,fun it is,,,,,,,,,
ronkh
« Reply #13 on: July 19, 2009, 12:58:32 pm »
Brilliantly clever man! Love all of your builds :-))
Ron.
Big Ada
« Reply #14 on: July 20, 2009, 04:50:50 pm »
I have had a go at making Pop Pop motors but none worked,can someone provide a simple diagram and how they work please.
Thanks,
Len.
« Reply #15 on: July 20, 2009, 05:12:38 pm »
Just Google Pop Pop model boats - dozens of references and explanations. I think somebody even wrote a book about them once.
Bernhard
« Reply #16 on: July 20, 2009, 05:31:40 pm »
gondolier88
    • Coniston Regatta
« Reply #17 on: July 21, 2009, 01:16:03 pm »
A very good link- the only problem being that the repeated boiling and cooling down of the 'motor' coil could result in fracture from a) The soft soldered joints or b) unlikely, but K&N metals are SO thin that it could also fracture.
Best workmanship would be to get a 4" X 2" X 1/6" peice of brass- available in K&N metals selection- make the hull the same shape but first silver solder a continuous length of copper pipe no more that 5/32" OD through the bottom of the hull with a coil as shown, first cutting the brass section to your required shape- when this job is done you can soft solder some tinplate sections to the top of the brass section to make the hull sides.
POP-POP boats work, for those that don't know, in quite a fascinating way- the candle first of all boils the water in the coil- this flashes to steam and pushes the water out at quite high velocity, but on reaching the bottom of the boat it condenses bacjk to water very quickly- creating a decent enough vacuum to pull water back into the coil- where it boils again and the process keeps on going as long as the candle burns- some POP-POP boats use a diphragm instead of a coil that 'breathes' with the flash and 'sucks' with the vacuum thereby increasing the effect- and these type make a FANTASTIC noise- kind of like a 1920's IC engine but without the smoke- everyone should have a POP-POP boat!!!!
Greg
Bernhard
« Reply #18 on: July 21, 2009, 04:43:04 pm »
Hi..Yes that true,,and they are fun to have and see working
Here is a big one
La Motte Piquet Battle cruiser pop pop. and Tucher&Walther African Queen
gondolier88
    • Coniston Regatta
« Reply #19 on: July 21, 2009, 07:06:23 pm »
WOW theres POP-POP boats, and then theres POP-POP boats!!!
Greg
Bernhard
« Reply #20 on: July 27, 2009, 09:01:47 am »
Hi.......Here is another pop pop...i be working on,,,the boiler i made of a paint spray can,,,with thin copper around,,,
Regards Bernhard
kno3
« Reply #21 on: July 27, 2009, 11:28:46 am »
What engine are you going to use this time?
Bernhard
« Reply #22 on: July 27, 2009, 11:57:43 am »
hi........Something like this......
gondolier88
    • Coniston Regatta
« Reply #23 on: July 27, 2009, 12:21:35 pm »
Hi Bernhard,
That boiler is wonderful- you know with not having a proper firebox you could rig up some sort of smoke generator in the boiler too to make it look extra genuine... O0
Greg
Bernhard
« Reply #24 on: July 27, 2009, 01:46:56 pm »
ohh yes that will be a good ide,,,,,to try to do that,,,,,,,,Thanks
Page created in 0.014 seconds with 18 queries.
