Pages: 1 2 [3] 4   Go Down
Author Topic: ------ Puzzle time -----  (Read 19400 times)
Marks Model Bits
  • No Mustang Mark
  • http://marksmodelbits.com/
    • Marks Model Bits
Re: ------ Puzzle time -----
« Reply #50 on: March 01, 2009, 08:37:29 pm »
Hi there is no such thing as half a hole,you can't have half a hole only a smaller hole
mark
I HAVE NOT FAILED, I HAVE FOUND 1000 WAYS THAT DON'T WORK.!!!!
catengineman
« Reply #51 on: March 01, 2009, 08:42:46 pm »
Your too smart for me  :-)) :D
R,
OMK
« Reply #52 on: March 02, 2009, 08:22:33 am »
No such thing as half a hole.
Re, the train question: It was an electric loco - therefore no steam??
« Reply #53 on: March 02, 2009, 08:30:05 am »
It's 1930, A train pulls out of the station in Scotland and travels south, it manages to reach a speed of 65 mile per hour. There is a wind blowing from the south at a constant speed of 15 mile per hour, taking all  this information here is the question
what direction does the steam go?
R,
The same direction as the train ?  {:-{
Bunkerbarge
« Reply #54 on: March 02, 2009, 08:35:00 am »
The steam goes into the cylinders, the smoke is what comes out of the funnel.
« Reply #55 on: March 02, 2009, 09:15:37 am »
The steam/smoke/soot/cigarette butts. leave the train vertically whilst the train proceeds at 65 MPH. It would have been left behind by the speeding train had there been no wind, but as it's blowing north at 15 MPH, it takes the debris with it.      maybe!!!
« Reply #56 on: March 02, 2009, 09:44:53 am »
                     Find the missing number
                   7     4            6    6           9    2
                      2                   1                 ?
catengineman
« Reply #57 on: March 02, 2009, 04:27:10 pm »
PMK  :-))
R,
amdaylight
« Reply #58 on: March 02, 2009, 04:49:09 pm »
Not quite,both steam and smoke come out of the stack. Unlike a ship after the steam exits the cylinders it goes to the bottom of the smoke box and inters a nozzle aimed up the smoke stack / funnel to create the draft to pull the smoke through the flues and out of the funnel, this is what gives the puff to the smoke. In fact a properly fired locomotive will have very little to no smoke it will be steam that you see exhausting the stack. In the photo below you can see the steam nozzle at the bottom of the smoke box, the tube that you see above it is called the petticoat pipe (or at least on this side of the Atlantic), between the petticoat and the sheet metal behind this, coupled with the steam nozzle is what causes a venturi in the smoke box and pulls the combustion gases out of the firebox and through the flues. The ring of pipe that looks like a crown is the " Blower", this is used when the loco is standing still to keep the fire going and the water hot by forcing the draft. Also show is a "Supper Heater" (all those little pipes). A supper heater takes the steam from the steam dome and runs it back into the flues to add extra heat, this is called "dry steam" and makes the locomotive more efficient getting more expansion out of the steam. You can tell the difference between a saturated steam locomotive and supper heated one by the slobber on the smoke stack. The saturated loco will have streaks of grunge running down the side of its stack.
Andre
over yonder in Portland Oregon
kenthompson
« Reply #59 on: March 02, 2009, 05:00:54 pm »
                   7     4            6    6           9    2
                      2                   1                 ?
   2   ALL TRIANGLES ADD UP TO 13.
kenthompson
« Reply #60 on: March 02, 2009, 05:07:08 pm »
HERES ONE FOR YOU .
What can go up a drain pipe down,
 but can`t go down a drain pipe up ??
Bunkerbarge
« Reply #61 on: March 02, 2009, 05:15:25 pm »
An Umbrella!
« Reply #62 on: March 02, 2009, 06:18:57 pm »
An angry rat!  %)
« Reply #63 on: March 02, 2009, 08:56:06 pm »
Correct, Ken.
 next one
               3   3   7
               1   5   1
               1   8   ?
find the missing number
OMK
« Reply #64 on: March 02, 2009, 09:35:28 pm »
6
« Reply #65 on: March 04, 2009, 10:52:52 am »
 Correct.  The lines are treated as whole numbers and the middle is subtracted from the top.
Puzzle 7      find the missing number
                                3
                               11
                               27
                               59
                              123
OMK
« Reply #66 on: March 04, 2009, 01:55:27 pm »
Could it be 251?
« Reply #67 on: March 04, 2009, 08:30:19 pm »
correct.    From the top, double the number and add 5
Now for sideways thinking
puzzle 7
                             B  C  D  G  ?
kenthompson
« Reply #68 on: March 04, 2009, 10:30:27 pm »
correct , Bunkerbarge.
Umbrella
OMK
« Reply #69 on: March 05, 2009, 01:54:56 am »
B C D G A  (musical notation, maybe??)
w3bby
« Reply #70 on: March 05, 2009, 08:11:43 am »
Interesting, I had it down to plus increasing multiples of 8, 3+8=11, 11+16=27, 27+32=59, 59+64=123, 123+128=251, different action, same result...
« Reply #71 on: March 05, 2009, 08:07:54 pm »
Very interesting, and well thought out, PMK.  I never thought of this, even though I was in the trade. It is not the path to travel, however.
« Reply #72 on: March 05, 2009, 08:15:06 pm »
Answer to B C D G ? N
« Reply #73 on: March 05, 2009, 08:27:31 pm »
Sorry, but no
d-jnana
« Reply #74 on: March 05, 2009, 08:44:15 pm »
Here,s one to discuss;
A train traveling due south at 60mph meets a fly traveling due north at 15mph. When the fly collides with the buffer beam, it ceases to travel north at 15mph and starts to travel in the opposite direction at 60mph. Between the time the fly is traveling north, and then south it must be stationary for an amunt of time. At that time it is in contact with the train, which must therefore be also be stationary.
AND
before anybody else says it, whats the last thing to go through the fly's mind?
It's a**e. :embarrassed:
Pages: 1 2 [3] 4   Go Up
Page created in 0.337 seconds with 22 queries.
