Author Topic: Motor/prop shaft Alignment  (Read 20615 times)
lozvik
Re: Motor/prop shaft Alignment
« Reply #25 on: September 12, 2009, 02:34:25 pm »
could it still be a fuse in meter if its reading voltage ok??
aestus57
  • Pentland Model Boat Club
« Reply #26 on: September 12, 2009, 02:48:32 pm »
Yes, the fuse is only there to protect the meter from being overloaded with amps.  Amperes are measured in the line of the circuit whereas volts are measured ACROSS the circuit. The continuity function of the multi meter should also still be working even with a blown fuse.
Keep plugging away and don't let it get you down, you'll certainly learn a lot from this little experience!  ;)
Think I'm suffering from De Ja Vu,   I'm sure I've forgotten this before!
lozvik
« Reply #27 on: September 12, 2009, 03:09:17 pm »
ok im gonna try a different meter later, ill let u know how it goes
pk1
« Reply #28 on: September 12, 2009, 04:33:53 pm »
Make sure you have got the leads in the right place on your multimeter or you will definitely blow the fuse
lozvik
« Reply #29 on: September 12, 2009, 05:00:58 pm »
im looking at the photo of the one shown above but its quite difficult to see the exact settings, I would appreciate if somone could tell me what all the settings should be on, thanks in advance
« Reply #30 on: September 12, 2009, 07:56:47 pm »
You looking for the lowest amperage, that's when the alignment is best.
lozvik
« Reply #31 on: September 12, 2009, 08:49:03 pm »
ok guys  sorted, I didn't have the positive probe in the unfused socket, doh! It all works now thanks for everyones input
Page created in 0.013 seconds with 18 queries.
