you could always make a liferaft float off with fine fishing line attached.
Also worth remembering that the boat is much lighter when in the water and full of the stuff than when you are carrying it around on the surface.
Something like ten pound line secured properly will probably be enough to bring a lot of models back to just below the surface where it can be grabbed before lifting clear of the water.
One of our members had the bad luck to sink his Applegarth tug at Rawdon Tarn a while back :'( While it was sinking, knowing the rescue boat would not be manned and out there in time, two of us ran to opposite ends of the sailing area and took a line of sight beyond the model to the far bank
When I then got out in the rescue boat, we were guided to the same position by the markers, and as the water is very clear, I could soon see the white superstructure of the boat - though several feet underwater. with the help of a leaf rake I had picked up from the clubhouse, and a wet arm :( ( it was deep) I managed to snag the rake in the very light stay for the foremast. being gentle with it, I managed to raise it almost to the surface and then while it was still under ( and light) grabbed it - more wet sleeves - all intact and sailing again the next week
. None of us would have beleived that such light rigging could have lifted the boat
