Author Topic: New Member Huntsman 47 " prop shaft help please  (Read 5055 times)
Andy Quirot
« on: April 27, 2009, 08:43:25 pm »
Hi there i am Andy i live in Jersey Channel Islands and i am restoring /rebuilding a 47" huntsman and i have looked at where the prop shaft will come out and it seems a bit odd as follows
1. It exits 17" or 430 mm from the transom
2. It seems to be about 15 degires  angle
i have attached a photo hope some one can help me Regards Andy Quirot
andyn
Re: New Member Huntsman 47 " prop shaft help please
« Reply #1 on: April 27, 2009, 09:18:58 pm »
That's the strangest propshaft I've ever seen....
It should be almost touching the model it is so close... Get the propellor you want to use with the motor you are using, and pull it inwards so that there is about 3mm clearance between the bottom of the prop and the hull. Like that it will dive in forwards under power...
Andy Quirot
« Reply #2 on: April 27, 2009, 09:54:48 pm »
Hi there yes this is a odd propshaft becouse it is a solid brass rod i dont want to drill out the hull till i am sure its in the right place Regards Andy Quirot
Andy Quirot
« Reply #3 on: April 27, 2009, 09:56:08 pm »
Do you think it exiting the hull in the right place Regards Andy Quirot
andyn
« Reply #4 on: April 27, 2009, 10:05:44 pm »
One word, No...
It looks far too far forward. Someone out there with a wooden huntsman will tell you where it's meant to be, it also looks to be at too much of an angle.
Vintage
    • Artisan Works
« Reply #5 on: April 27, 2009, 10:18:30 pm »
Hi Andy
If it's any help I have an old Veron Huntsman which is 42" long & the propshaft centre line exits the hull approx. 17 cm forward of the transom. If your boat is 47" long then it's 1.12 x up on mine which would mean your propshaft should exit approx. 19 cm forward of the transom (17 cm x scale of 1.12 = 19.04 cm).
Not sure that the old Veron kits are 100% accurate but it should give you a rough idea of positioning.
Hope this helps  :-))
Mark
Edited to be more accurate  O0
Reproduction wooden stands for the full range of vintage Star Yacht models are available from Vintage Pond Yachts
omra85
« Reply #6 on: April 27, 2009, 10:29:57 pm »
Andy - this site may help you. Scroll down to about page 3 (submerged drive).  The principle is the same whatever the boat.
http://www.icboats.org/boat/documents-pdf/glow%20fuel%20engines.pdf
Danny
Andy Quirot
« Reply #7 on: April 27, 2009, 10:51:02 pm »
Hi Danny thanks for the link BUT it all seams to be about IC engines i will carry on reading but i dont fing the page you say Regards Andy Quirot
« Reply #8 on: April 27, 2009, 11:02:21 pm »
Hi Andy will haev a look at my huntsman tom night and the instructions and get back to you with the proper dimentions
Stav
Andy Quirot
« Reply #9 on: April 27, 2009, 11:06:44 pm »
Hi that will be great can i buy a copy of the instructions from you Regards Andy Quirot
« Reply #10 on: April 27, 2009, 11:08:01 pm »
pm sent
Ramon
« Reply #11 on: April 29, 2009, 12:23:59 pm »
Hullo Andy,
I have just read this post for the first time having been away a few days.
I am also building a 42" Huntsman but from the Vic Smeed plan. This gives an exit point approximately the same as the measurement given by 'Vintage'. I have just measured the exit point on mine and it is 175 mm from the transom. I tried to keep my shaft angle as low as possible which resulted in the prop being a bit closer to the stern than I would have liked hence my initial concern but consensus of opinion at the local water is that it should be okay.
If you take a look at http://www.modelboatmayhem.co.uk/forum/index.php?topic=14357.0 and scroll down to post 73/74 on page 3 there is a pic of my prop set up which may help you.
Best of luck with your build  :-)) - Ramon
Andy Quirot
« Reply #12 on: April 29, 2009, 01:09:54 pm »
Hi there yes i have looked at those photos very nice remind me not to show you any of mine photos because I think you make a lot of builders envy  with your build quality. Photos may help I can make a temp let from the photo with the shaft extended and use that to measure where it comes from the hull??. Thanks for the advice regards Andy Quirot (Jersey Channel Islands)
Andy Quirot
« Reply #13 on: May 01, 2009, 07:50:33 pm »
Hi there anybody out there go a set of plans that they can take the mesurements from and let me know where to mount this prop shaft as i would like to get on with the bild and sea triles Regards Andy Quirot
« Reply #14 on: May 02, 2009, 06:09:24 pm »
Hi Andy the measurement that you have mentioned in your first post is correct BUT one question springs to mind .Have you replaced the woodwork on the hull at all,the reason I ask is if you have I think that you have not relieved the prop hole enough.I have had mine out today and fitted the propshaft to it and there is enough clearance for a 60mm prop in mine.There are no dimensions on the plans at all PM me your full address as my scanner has versed to work and I will photocopy the original plans in work and send them to you.
Stav
Page created in 0.043 seconds with 22 queries.
