Author Topic: Glow to Spark ignition ?  (Read 2185 times)
John East
« on: May 07, 2009, 06:59:00 pm »
Hi
Has anyone had any experience with this type of conversion ?.
I understand that some of the model flyers have done it, I also see that there are some kits available, but quite pricey.
Cheaper fuel and easer starting seem to be main advantage.
So over to you guys
Thanks. John
StarLocAdhesives/FiveStar
Re: Glow to Spark ignition ?
« Reply #1 on: May 07, 2009, 07:10:25 pm »
both myself and a freind converted a few meco engines about 15-20 years ago, one was in a boat ( but not mine so dont know much about that) , the rest were for planes, it was a real botch job as nothing was purchased to do it apart from the spark plug and some 2stoke oil ( even the petrol was syphoned out of MY car )
We made a split collet to fit around the front of the crankcase out of a bit of alloy block, using a drill and a hacksaw....., used a bolt to tighten it up so it fitted onto the front of the engine, a nail was inserted into a hole in it as a handle to allow it to be turned to alter the timing, a microswitch was fitted to it, with a condenser fitted accross the terminals ( i think, but maybe from one contact to earth?, not sure!) , the microswitch was operated by a bal bearing that was glued into a hole drilled in the prop driver, coil  was from a ford cortina, batteries from a model car....
It took a few goes to get the timing right as the microswitch was the wromng type it had to be off when pressed ( couold have been on, one way it was wrong!)
It ran fine , i had a merco 60 ( i think it was a 60 ) on a large vintage model once i bought a mini coil from a swapmeet , it ran a much bigger prop as petrol power than glow
It was a real botch job , using no decent tools and it worked so it must be easy to do well using tools
« Reply #2 on: May 07, 2009, 09:25:15 pm »
The mechanical switch described will have a rather short life - they usually quote something like "better than 10 to the power 5" operations for switches in the parts catalgues.  A 2 stroke at 10000rpm gives about ten minutes before its on borrowed time, but a magnet and a hall effect device, or a bit of opto electronics should do the job and be as long lasting as the rest of the engine.
w3bby
« Reply #3 on: May 10, 2009, 08:25:30 am »
Here's a link to such a conversion http://www.powerboat-friends-freising.de/usergallery/thumbnails.php?album=612
hendrikX is active on Jims and Xtreme RC boats if you would like to get more info.
