It's an electronic carrot held in stasis in hyperspace within a black hole. You will need to reach Warp Factor 10 in order to reach it. I believe FLJ can supply the necessary components (in kit form) to achieve this but the cost of assembly may be rather high.
warp factor  10 !! why go so slow when you can use the   Infinite Improbability Drive , thus be every where at the same time..
However this should be used carefuly as
"An earlier attempt at using the improbability drive, Starship Titanic,  In theory, the infinite improbability drive would make it infinitely improbable that anything would go wrong. It was not successful, however, ending in a "Spontaneous Massive Existence Failure." This was because, in these earlier times when the nature of improbability was less well understood, it was not appreciated that any event that is infinitely improbable will, by definition, occur almost immediately."
