Neil, about the size I would recommend 6 Volts (fair enough as you don`t need too much power in that boat). A micro-controller like (i.E.) Graupner Micro Speed 10 and a motor from Maxon or Faulhaber, which is an ironless type. The advantage of these motors: Their consumption is unbeatable. Have a look for a supplier in the UK. Decide a Motor with 6 Volts and about 8500 Rpm. The diameter of such an irolness motor is very easy to calculate: The diameter of the Prop plus 25%- then you will find a really good propulsion for it. Take 5 or better 6 cells NIMH with about 1200mAh. A motor like this will take about 250mAh max. which gives you a minimum of 3 hours of joy with that boat. I would recommend a prop with 25mm dia- though a motor with about 30mm dia would be good enough for it.If you need any further deatils, have a look under
www.maxonmotor.comHowever- first of all make a calculation with the balancecounter and then calculate the deadweight for deck and fittings. If possible, do weightwatching from the very start. Try to replace the wooden items like deck and superstructure and replace them by plasticard. Instead of a wooden mast take a lightweight-aluminium-tube.
As mentioned earlier- it`s not impossible- if you know how to do.
About the teenies in the bus.....- I am absolutely with you- as my son is age 13....
With your job Beta-blockers must be given every morning.....
Anyway- nothing can get us GOGS down!
It reminds me on a joke I have heard a while ago:
There was this business-man, taking the bus. It was overfilled with screaming teenies, though he decided to stay beside the driver.
He seems not to notice the roaring noise in the background, just doing his job- smiling. After a while the business-man had enough.
"How can you stand that awfull noise?", he asked the busdriver. No answer. He fighted again against the noise in the back and replied his question. The busdriver looked at him, smiled an stopped at the next buststop, selling some tickets and carried on. The manager took out a paper and wrote the question again on it. He passed it on the next stop to the driver. The driver grabbed the
paper and left an answer:
"Sir, I`m neither on drugs or pills. I am not foolish anyway, but I am def since birth. It was the reason why they had given me the job and gave me an extra of 25% as nobody wants to serve that line".
Jörg
