Author Topic: water cooling  (Read 3109 times)
ether823
water cooling
« on: June 12, 2009, 02:38:53 pm »
Hi all, I`m in the process of buying a MMB electric motor and it needs to be water cooled. Can someone tell me if the piping needs to be 6mm or 10mm dia to go around the motor. Regards Pete
Mankster
  • Wheelerdealer
    • RC Model Submarines
Re: water cooling
« Reply #1 on: June 12, 2009, 03:39:01 pm »
10mm is huge, you never get that to bend around a small motor. 4mm or so I would have thought would be better.
toesupwa
  • USA'd ex Brit
Re: water cooling
« Reply #2 on: June 12, 2009, 03:49:56 pm »
I usually use 1/8" - 3.2mm or 5/32" - 4mm Ali or copper pipe as cooling tube round a 550 size motor.
Re: water cooling
« Reply #3 on: June 12, 2009, 05:34:26 pm »
10mm is miles to big.
Dont know the diameter of the motor but look here it might help.
http://www.cornwallmodelboats.co.uk/acatalog/water_cooling.html
Arrow5
Re: water cooling
« Reply #4 on: June 12, 2009, 05:49:13 pm »
...and a motor mount with cooling slots helps to let air into the motor.
..well can you land on this?
ether823
Re: water cooling
« Reply #5 on: June 12, 2009, 05:54:25 pm »
Many thanks gents, the motor I am going to use is a MMB900, which is quite a hefty beast. Great photo`s by the way.  Pete
