Author Topic: Motor help urgently needed  (Read 4788 times)
J.beazley
  • The building never ends
« on: November 01, 2006, 09:12:56 pm »
Hello everyone, in need of some help urgently.
refitting a model and in desperate need of some motorsheres the problem
i need 2 motors running 7.2 volts with a rpm around 11,000 or above, using as little amps as possible and to be small and light (not asking much ::) really)
im binning my 380 type motors as there to heavy and i keep breaking motor mounts  ::)
so all in all i need some motors smaller then 380 but run about the same  ???
im sure some of you folk will guide me in the right direction
Jay
andywright
Re: Motor help urgently needed
« Reply #1 on: November 01, 2006, 09:18:14 pm »
Try this site
 http://www.fastcomponents.co.uk/index.php?cPath=43
not had any experience of there motors but they look the part.
Sorry I couldn't be quicker with the answer!!!!
Navigational Aids vessel Master. Old Conway 70-72
J.beazley
« Reply #2 on: November 01, 2006, 09:28:55 pm »
cheers for useful link  ;D
the motors look small enough for the job but i dont think they could turn a 35mm prop at around 11,000 rpm  ???
reason for the urgent help is i need to get on the water for sunday but not having motors doesnt help lol  ::) ;D
Jay
FullLeatherJacket
« Reply #3 on: November 02, 2006, 09:08:55 am »
Jay
In my experience I haven't come across any motors which would fit yor bill. 35mm is a big prop to spin at this speed, even for a Speed 400 (380). If you can't reduce the weight of the motors could you maybe use a lighter battery pack?
Simply for your information, my mini-Swordsman (20 ins) uses one Speed 400 and a 28mm brass prop running on 6 x AA Sanyo Nicads @ 800mAh. Goes like greased weasel-pooh.
PS Thanks for the link, Andy.
J.beazley
« Reply #4 on: November 02, 2006, 11:41:22 am »
my boat is just under 20in long, at the moment its running 2x380 type motors that came out a fast electric hull.
i think im going to replace them with some race lightweight 400 type jobbies as i cant find some small enough motors for the job  :'(
need to buzz modelpower and get some lighter packs off them aswell at some point in the near future.
Jay
Subculture
    • Dive-in to Model submarines
« Reply #5 on: November 02, 2006, 04:08:28 pm »
380's are the same size as a Speed 400, aren't they?  ???
Maybe you should consider going brushless if you want high torque combined with small size/weight.
Controllers won't be cheap though.
J.beazley
« Reply #6 on: November 02, 2006, 04:23:05 pm »
looking in the ripmax book think im going to bite the bullet and buy a pair of Groupner speed 300 motors running 29,000rpm each.
under load they should be rather quick i think ???
Jay
Subculture
« Reply #7 on: November 03, 2006, 12:20:55 pm »
What size props are you running?
J.beazley
« Reply #8 on: November 03, 2006, 03:00:10 pm »
im running a pair of 35mm props, will try and get a picture up for people to see .
Jay
Subculture
« Reply #9 on: November 03, 2006, 04:13:58 pm »
In that case I'd recommend either a gearbox or a bigger motor.
Andy
J.beazley
« Reply #10 on: November 03, 2006, 08:51:38 pm »
heres a couple of pics Shipmate60 (bob) has helped do for me, cant claim i done much as bob did most of the work to get it ready for the Beale show and here i am still tinkering with it.
Jay
Page created in 0.265 seconds with 22 queries.
