Author Topic: new model steam launch  (Read 10614 times)
pipercub1772
« on: August 25, 2009, 08:41:07 pm »
my first atempt at steam about 18 month work ,picked up loads of info from mahem ,thought i would take some picks before all that oily stuff gets running about just got bits to do yet like curtons and life belts hope these picks work /allan
Re: new model steam launch
« Reply #1 on: August 25, 2009, 08:44:45 pm »
Thats one beautiful looking boat Allan, well done.  :-))
boatmadman
« Reply #2 on: August 25, 2009, 09:17:41 pm »
WOW what a beaut!
Did you build the hull? What plans did you use?
One problem though - cant see the engine, what is it? :-))
« Reply #3 on: August 25, 2009, 10:26:38 pm »
Steam engines  love oil----you can never have too much.
But then you have to keep that beautiful boat clean--still a good rag (PS no cutting bits out the douvet cover, you get into deep trouble  <*<) does the trick
Love the work  :-)) :-))
Steamer
« Reply #4 on: August 26, 2009, 04:15:11 am »
Oh the oily stuff just adds character!...... O0
Well done Pipercub.....from a fellow Piper...... :}
ROSYTH
  • Steam glorious Steam..
« Reply #5 on: August 26, 2009, 01:22:59 pm »
Excellent piece of work, very well done indeed. Good looking launch.
NOW
Can we see a link to it on the water soon please, as its always good to see how they perform.
keep up the good work and what pray tell is your next project?
cheers
Rosyth
Bernhard
« Reply #6 on: August 26, 2009, 01:31:01 pm »
wowww what a great looking launch...well don,,,,,,,,,,,,,,Regards Bernhard
pipercub1772
« Reply #7 on: August 26, 2009, 09:46:07 pm »
thanks for the coments ,dont know wats next seams to take over youre life sometimes this model boatingi think it will be a open launch ive  been inspired by some of bernhards models ,putt a pick of the engine its a 3/8by 3/8 occilator runs well on 10 /30 psi reverse works well if you have a few revs on  but not 100% if you are just ticking over dont know if thats normal with this type of engine , i bought the hull and scratch built the rest by rack of eye and looking at various pictures mcsteam boiler ,engine from ebay
Flyerjeff
« Reply #8 on: August 29, 2009, 01:43:38 am »
Beautiful!!!
andywright
« Reply #9 on: November 28, 2009, 08:19:59 pm »
where did you get your cleats and fairleads?
Navigational Aids vessel Master. Old Conway 70-72
HS93 (RIP)
  • I cannot spell , tough
« Reply #10 on: November 28, 2009, 08:33:31 pm »
andywright
« Reply #11 on: November 28, 2009, 08:34:50 pm »
thanks for that.
andywright
« Reply #12 on: November 28, 2009, 09:23:15 pm »
Pipercub
Did you just fit the wooden lagging around the bare boiler or is there insualing  material in between?
Andy
Underpressure
« Reply #13 on: November 29, 2009, 09:54:56 am »
Andy,
       the Cheddar Models method was to spray the whole boiler with black heat proof paint and then glue the wood lagging on using cyno or epoxy. The brass bands were then fitted to help retain the wood.
Hope that helps.
andywright
« Reply #14 on: November 29, 2009, 10:26:21 am »
Cheers, was wondering how to hold all the wood on and tighten the belts, alltough I thought of glueing the wood to light woven fibre glass cloth and wrapping it around the boiler then brass band to hold it on. May still do that to stop the boiler getting covered in cyano or epoxy, use cardboard tube for a former, then transfer to the boiler.
Chuffy
« Reply #15 on: November 29, 2009, 03:15:04 pm »
You could try double sided tape as per the MH&B instructions for my Topaz, worked well on my boiler.
Paul
Underpressure
« Reply #16 on: November 29, 2009, 04:10:13 pm »
Paul
That sounds like a good solution. I never liked the idea of epoxy and hot boilers.
kno3
« Reply #17 on: November 30, 2009, 01:15:03 am »
Very nice work!
I'd like to know more about the engine. The throttle/reversing valve position and steam pipe connection is unusual and not really clear to me. Do you have a betetr picture?
boatmadman
« Reply #18 on: November 30, 2009, 12:50:13 pm »
I recently fitted insulation and wood to a boiler for the first time and spent ages wondering how to do it. In the end, I realised the easiest way for me was to cut out the lagiing, hold it on the boiler with elastic bands, then cut and fit the wood under the elastic until all was ok.
I then fitted the brass bands and tightened them up to hold wood and insulation in place - no glue, no paint, seems to have worked so far. :-))
Ian
andywright
« Reply #19 on: November 30, 2009, 03:39:25 pm »
Thanks for all your tips, I have glued the wood on with superglue, and when it is varnished I will add the bands, apparently when the boiler is steamed, because of the heat and expansion, the superglue will come off the boiler, leaving the planking held on with the bands. I thank Mike Abbot at Maccsteam for this tip.
andywright
« Reply #20 on: November 30, 2009, 03:48:26 pm »
Another question, who makes  an oily water separator, I see Mr hemmens has one on his site for £££££, don't even mind a kit. No body else seems to list them.
Underpressure
« Reply #21 on: November 30, 2009, 04:46:41 pm »
Blimey, you don't hang about do you?
There is a guy who lists gas tanks and condensers on ebay. Also they are listed in Cotswold Heritage's price list. I can't find one big enough for my V4 tug, so I'll make one, or use a car catch tank that all the hot hatch guys have fitted these days (I know this as I have one on my Buell  :embarrassed:).
HS93 (RIP)
« Reply #22 on: November 30, 2009, 04:53:28 pm »
I got a few of these recently have not used them yet but they look very well made and a good price he does have a ebay shop that makes it easy to buy as the germans deal in bank transfers most of the time, he may do paypal on his main site now I have not noticed.
http://translate.google.com/translate?u=http%3A%2F%2Fwww.modellbau-niggel.de%2F&langpair=de%7Cen&hl=en&ie=UTF8
http://shop.ebay.de/awlnu66/m.html?_nkw=&_armrs=1&_from=&_ipg=
Peter
HS93 (RIP)
« Reply #23 on: November 30, 2009, 05:02:09 pm »
or try this very nice man, he may sell them separate . pound / dollar is good at moment well it was when I posted so it's not a bad buying from USA
http://www.monahansteammodels.com/newsandinfo.aspx
peter
ROSYTH
« Reply #24 on: November 30, 2009, 07:53:49 pm »
Have a word with Keith at http://www.mainsteam.co.uk/condensers.htm he makes some real nice ones too ok along with a few other bits and bobs.
R
Page created in 0.227 seconds with 22 queries.
