Author Topic: Mystery engine  (Read 5079 times)
MCR
Mystery engine
« on: August 30, 2009, 08:55:04 pm »
Could anybody please identify this engine?
gondolier88
  • www.coniston-regatta.co.uk
    • Coniston Regatta
Re: Mystery engine
« Reply #1 on: August 30, 2009, 10:43:19 pm »
There are people who know more about vintage model engines on here, but i'll take a punt that it's amateur design and made- very nice though.
It's unusual to have a cylinder block that is made from one casting and it doesn't have reversing gear, the trunk guides are also very 'workmanlike', that's how it looks to me anyway.
Have you steamed it? Got a boat for it yet...? :-))
Greg
MCR
Re: Mystery engine
« Reply #2 on: August 30, 2009, 11:02:46 pm »
A friend brought it to me tonight its a piston valve engine.
Putting air through it after a sluggish start off she went reverse is via the leaver you can see in the photograph I was thinking Hemmens for some reason but I'm unsure.
Bunkerbarge
Re: Mystery engine
« Reply #3 on: August 30, 2009, 11:20:50 pm »
Strangely enough that cylinder block is identical to my Hemmens Caton 'V' four units.  Perhaps it is a home made twin using a 'V' four as a donor or maybe Hemmens made a twin at one point using the same head block.  The Catons were reversed using a shuttle valve in the supply lines to the cylinders so not surprising this is not reversible.
MCR
Re: Mystery engine
« Reply #4 on: August 30, 2009, 11:27:08 pm »
It is reversable by the way.
knoby
Re: Mystery engine
« Reply #5 on: August 30, 2009, 11:35:59 pm »
I'm sure hemmings did make a twin like that , I nearly bought one. It was over 10 years ago that i looked at them so time may have fogged the memory somewhat, but i remember the throttle/reversing lever looked a lot like that. I was particularly interested in it because it only used i channel for fwd/rev & throttle. I will have a dig through the old files & see if i still have the literature on it. Of course i could be totally mistaken , it wouldn't be the first time.
cheers Glenn
MCR
Re: Mystery engine
« Reply #6 on: August 30, 2009, 11:46:49 pm »
Thanks Glenn that would be great
Mark
knoby
Re: Mystery engine
« Reply #7 on: August 30, 2009, 11:50:28 pm »
just had a quick look, but couldnt find any pics> but i did find a letter from hemmings that they sent with the missing pics. it was called a max 2 engine. i will continue to look through my things to see if i can comw up with some pics.
Cheers Glenn
knoby
Re: Mystery engine
« Reply #8 on: August 31, 2009, 12:00:56 am »
found a pic on the web
knoby
Re: Mystery engine
« Reply #9 on: August 31, 2009, 12:04:05 am »
its close but not identical. of course could be same basic engine at different stages of development.
Hope it helps cheers Glenn
MCR
Re: Mystery engine
« Reply #10 on: August 31, 2009, 12:19:28 am »
Many thanks thats great
Mark
ian kennedy
Re: Mystery engine
« Reply #11 on: August 31, 2009, 01:53:33 am »
Hi chaps,
For your info the green engine is a Caton twin as finished from John hemmens in the mid to late 80's and the red engine is the improved caton engine called the Max 2.
Both engines were controlled by two radio channels, one for reversing and the other for steam regulation.
Hope this helps.
Ian
Bernhard
Re: Mystery engine
« Reply #12 on: August 31, 2009, 06:37:05 am »
Hi.........yes that what it is, A caton,,i did one time have one
http://www.youtube.com/watch?v=_e2WVGvl-W0
Regards Bernhard
gondolier88
    • Coniston Regatta
Re: Mystery engine
« Reply #13 on: August 31, 2009, 07:50:04 am »
There should be pub quizzes on this kind of thing- anyone want to make a team????? :-)) {-)
Greg
Page created in 1.047 seconds with 22 queries.
