Author Topic: Nutty problem  (Read 6377 times)
Umi_Ryuzuki
Re: Nutty problem
« Reply #25 on: September 05, 2009, 06:18:00 pm »
Thicken the area under the mounting point with  some 3mm plywood, and use blind nutsO0
Corposant
Re: Nutty problem
« Reply #26 on: September 06, 2009, 04:08:37 pm »
Brian,
        Thanks for the trouble you've gone to on my behalf - much appreciated. Thanks too for the offer of a BA set. I've actually got open ended spanners but anticipate a problem getting one on at the right angle in the available space. It's only going to be needed for the last half turn or so (a bit of plastic tubing will get them most of the way).
I'm being unbelievably pedantic about this because the chances are the blocks will never need removing!
Corposant
Re: Nutty problem
« Reply #27 on: September 06, 2009, 04:15:18 pm »
Umi,
      Thanks for the thought - but I can't screw the blocks in like a bolt - they'd almost certainly end up at the wrong angle! (See my earlier post with a sketch of their construction.) Or am I missing something in your idea?
Tankerman
Re: Nutty problem
« Reply #28 on: September 06, 2009, 04:35:59 pm »
 Mike,
  Take a look at the catalogue on this website, there are BA spanners and spinners: www.eileensemporium.com
 Chris
Corposant
Re: Nutty problem
« Reply #29 on: September 06, 2009, 05:21:54 pm »
Chris,
        Brilliant! Down to 16BA!!! Just the job. Their other stuff looks promising too!
Thank you so much,
Page created in 0.062 seconds with 17 queries.
