Helgebe,
I appreciate your problem, however, such is the nature of this type of valve.
If your problem is water/condensate remaining in the cylinder then you must find, and eliminate the cause of this…. changing the valve timing is not the way to do it.
If you adjust the timing such that the exhaust port remains open until the piston reaches the end of it’s stroke then the steam port will not open until the piston is well past TDC or BDC… approx 23.6 deg in either case.
This will certainly give you starting problems and will also cause pressure surges in the steam chest…. It will also make steam CUT-OFF late, by the same number of degrees; hence little or no expansive work will be done and the benefits of the more advanced type of valve gear will be lost.
The whole idea of the exhaust closing before TDC/BDC is to allow some compression of any remaining steam to bring it back up to something approaching boiler pressure in order to eliminate/reduce these pressure surges.
Unfortunately you can’t have it both ways with that valve design…. The only type that will give you a fighting chance of both would be the Line-on-Line type as shown on my diagram Fig 10 but you will not be able make use of steam expansion.
This would also mean modifying the valve, which I do not recommend.
I would recommend you set the valve gear as detailed, which is the correct method for this type of valve gear, and then seek to find alternative solutions for the water /condensate problem.
There are many causes for water/condensate remaining in the cylinder including: -
The use of wet steam at too low a pressure. (Which will be at a lower temperature to start with)
Engine too cold or cooling down too much whilst running (e.g. stopping for too long before re-starting)
Running too slowly, especially with wet steam at too low a pressure, since this will allow more time for the heat (in the cooler steam) to escape from the steam/engine resulting in condensate.
Possible remedies.
Use higher steam pressure, which will then be at a higher temperature to start with.
Fit and use a steam dryer (what Cheddar call a super heater).
Try not running too slowly, especially if you are not using dry (super heated) steam.
Don’t stop the engine for too long before restarting.
Lag the outside of the cylinders to retain heat; also the steam feed pipes feeding the engine from the boiler.
Best regards.
AlexC.
