Author Topic: Revese gearbox for Stuart turner twin launch engine  (Read 17310 times)
UKJonathan
« on: October 19, 2009, 12:06:58 pm »
Hi can anyone tell me where I could get a gearbox so I can get reverse on my Stuart turner twin launch engine ?
Thanx
Jonathan
flashtwo
Re: Revese gearbox for Stuart turner twin launch engine
« Reply #1 on: October 19, 2009, 01:10:56 pm »
Try this link to Mainsteam Models:
http://www.mainsteam.co.uk/gearboxes.htm
Ian.
HS93 (RIP)
  • I cannot spell , tough
« Reply #2 on: October 19, 2009, 02:18:47 pm »
Mainstream use a car gear box by the looks of thing with a brass cover  it looks like the HPI Savage reversing gearbox for a IC buggy so it has plenty of strength about £29 they need a servo but the engine does not need to slow right down. the HPI one has been used by a lot of modelers for reverse on steam engines.
Peter
« Reply #3 on: October 19, 2009, 02:46:49 pm »
Thought about a reversible pitch prop Jonathan ??
 regards  ian.
UKJonathan
« Reply #4 on: October 19, 2009, 05:37:01 pm »
hi Ian,
            what is a reversible pitch prop  ?? I am new to this and still finding my feet. Also the buggy one sounds interesting and cheap. I don't mind using a a servo to change from forward to reverse if that is how it works.
jonathan
gondolier88
  • www.coniston-regatta.co.uk
    • Coniston Regatta
« Reply #5 on: October 19, 2009, 06:22:26 pm »
Hi Jonathan,
Could you not get the reversing gear castings for your engine then hook a servo up to the engine direct?
Greg
UKJonathan
« Reply #6 on: October 19, 2009, 10:17:00 pm »
Hi Greg,
                not sure where to get them and I don't have any expereance in milling them if they need it.
jonathan
gondolier88
    • Coniston Regatta
« Reply #7 on: October 19, 2009, 10:49:11 pm »
Hi Jonathan,
Stuartmodels.com- Go here and follow links to Reverse Gears & Feedpumps- listed as Reverse gears for Twin Launch.
If your looking for someone who could machine them for you get in touch with fellow member Bogstandard- he is great to deal with, fast, efficient, not overpriced at all and is a nice guy to boot- give him a PM and see what he says- he's usually more than happy to help a fellow steam nut- and he also has use of a personal machine shop so his work is top notch.
Greg
gondolier88
    • Coniston Regatta
« Reply #8 on: October 19, 2009, 10:51:28 pm »
Ive just checked the ST website for the reversing gear- and it isn't listed- because your engine should have come complete with the reversing mech' already on.
Where did you find this engine?
Greg
UKJonathan
« Reply #9 on: October 20, 2009, 10:26:57 am »
hi Greg
            I bought it of someone I knew but it did not have the reversing bit with it, it would be nice as I said if I could get the proper one but I'm not that clever to machine parts so I may have to look to the HPI Savage reversing gearbox route which I really did not want.
jonathan
« Reply #10 on: October 20, 2009, 01:48:41 pm »
Sorry for delay Jonathan, R/P prop is one where you can go from forward to reverse by allowing the prop blades to be swung from posiitive to negative pitch mechanically without a change in engine speed or rotation. Send a me P/M with your E-Mail address  O0 :-))
  You don't state which twin launch engine you have? It must be the Later S/T engines that have the reversing gear (Stevenson's Launch Link) on the Double Ten, if it is that one, fitted as standard as the original engine castings were NOT supplied with this feature and it was many years before an additional kit was produced and sold as an extra. (Long before Vale took over)
Regards  Ian
sweeper
  • When all else fails, read the instructions
  • Location: On the edge of reason, in the state of Confusion
« Reply #11 on: October 20, 2009, 03:46:14 pm »
If you are interested in gearboxes, this site may be of use to you.
http://members.tele2.nl/s_weggeman/CT.htm
It's a well put together site.
Usual disclaimers apply.
gondolier88
    • Coniston Regatta
« Reply #12 on: October 20, 2009, 05:28:56 pm »
Hi Jonathan,
Could really do with a pic of the engine and boat then we could really give you tailored advice.
Greg
UKJonathan
« Reply #13 on: October 20, 2009, 06:09:17 pm »
Hi Greg here is a couple of pics first time so hope they come on
jonathan
UKJonathan
« Reply #14 on: October 20, 2009, 06:11:22 pm »
Hi Greg
sorry but two same here is another
Jonathan
HS93 (RIP)
« Reply #15 on: October 20, 2009, 06:27:38 pm »
If you go down the HPI gearbox route ( they are quite small and easy to use) and at £22 cheap as chips
http://www.rcpitstop.co.uk/hpi-savage-reverse-module-hp87032-39-p.asp
UKJonathan
« Reply #16 on: October 20, 2009, 07:00:41 pm »
Hi
 If I used the HPI gearbox then I have been told I have to shorten one side as the shaft is too long because the reverse shaft is around the long shaft. I just have to mill the prop fittings a little larger so I am told.
jonathan
HS93 (RIP)
« Reply #17 on: October 20, 2009, 07:27:48 pm »
you just shorten the shaft, and bore out the coupling OR use the car bits.
peter
Bradley
« Reply #18 on: October 20, 2009, 07:36:42 pm »
Don't go down, what appears to be, the complicated route of fitting a reversing gearbox to a steam engine.  ALL steam engines, that I know of, both model and full size reverse by stopping and then reversing the complete engine using the reversing lever.  Even on full size steam locos and traction engines reverse is obtained in this way.  Some traction engines/road locos have a 3 or 4 speed gearbox but the appropriate gear is selected whilst the vehicle is stationary and then the regulator is opened to start moving.  This system gives the same number of speeds in reverse as in forward.  I have no doubt that full size steam propelled boats operate via the same principle.  The reversing gear is all part of the engine and, in the case of a model boat, is operated by a servo moving the reversing lever through the sequence forward-neutral-reverse and vice versa.  I think you would regret it if you started chopping your engine about to fit a reverse gearbox.
Hope this is of some help  :-)).
Derek.    :police:
« Reply #19 on: October 20, 2009, 07:45:09 pm »
hi there
I am afraid its looks as though the gentleman has to go down the road of fitting a reversing gearbox to the steam engine; with the photographs he has put on I cannot see any evidence of any secondary reversing concentrics on the crank shaft.  There is definitely no indication of a 'Stevenson's link' for the reversing system.   That is just one of the few ways of reversing a steam engine - using Stevenson's link.
I have just been on Stuart Turner's website myself looking for the reversing bits.  Also, out of curiosity of much these things cost.   I would have to remortgage me house to pay for one - by gum I did get a surprise.  O0 %%
aye
john e
bluebird
Bartapuss
  • Deltic's Rule OK!
« Reply #20 on: October 20, 2009, 07:50:30 pm »
Derek is spot on here, what you need is the Stephenson's linkage for the slide valves on your engine an additional extra that should be available from Stuart Turner and should not be too hard to fit to your engine.
 I wouldn't go down the variable pitch propeller route as you will find that as the pitch is increased/decreased the load variations will cause the engine to speed up and down and especially at zero pitch the engine will race away as there would be very little to no load present, unless you can include some sort of governor or regulator to control the steam flow in sinc with the props pitch, this I think would be a very complicated system.
Every time I learn something new, it pushes something old out of my brain - I says wot I likes and I likes wot I say!!!
Bradley
« Reply #21 on: October 20, 2009, 07:53:25 pm »
Hi John (Bluebird),
I appreciate what you say but I have never come across a Stuart Turner launch engine that does not have a reversing system.  This looks like a nicely built engine and I would be surprised if it was not designed to have a means of reversing it.
Derek.    :police:
« Reply #22 on: October 20, 2009, 08:08:13 pm »
Hi just a passing thought no body has mentioned a Kitchener rudder for reversing
aye
john
gondolier88
    • Coniston Regatta
« Reply #23 on: October 20, 2009, 08:28:55 pm »
First of all Jonathan you would find it impossible to fit any reversing gearbox after the engine- you simply havn't got any room!!! Your shaft is going to be at a really daft angle to start with!
Secondly- contact ST and tell them you have an old design twin launch engine without reversing gear- ask them if they could send the reversing castings as spare parts. Next contact Bogstandard via PM and enquire if he will machine them for you-i'm sure he will- if not someone at your local model engineering club may do it for you.
Lastly- Stephenson's link is far from being the only, the best, or the most suitable for this engine (although that is what the majority of engunes are fitted with, and is indeed what ST supply with the Twin Launch now).
The most suitable for this situation would be a slip eccentric arrangement (extremely hard to make in model sizes), next a Kitchen rudder would be very viable in this boat- plenty of room in the counter stern to fix the arrangement, and lastly a reversing pitch prop' (although these too are quite hard to make).
Greg
HS93 (RIP)
« Reply #24 on: October 20, 2009, 08:32:55 pm »
Derek.    :police:
Derek have you used one of these boxes on a model steam plant or seen one in operation ???do you run steam boats? do you think I would propose a member to spend money if it did not work in this situation ?? one you don't have to stop the engine to go in reverse I know because i fitted one to A single that would not re start I am fitting another now to a single, you don't have to chop the engine about to do this you just connect to the box the same way you would to a prop shaft , i wish people on this site would stop saying things wont work until they have tried it or have first hand knowledge, and there is no reason not to put ideas forward but to tell people who have done it it wont work is a pain
Peter
