Author Topic: Speedo current draw ??  (Read 2081 times)
benjaml1
« on: October 26, 2009, 02:55:54 pm »
Hello, On connecting my 125A "SUPPO" electronic speed control I get quite a spark ( using my safety loop as isolator) & when programming (I stopped) it was getting quite warm. Is this normal ?? Should I be running cooling water during this procedure ?? Motor wasn't running, wiring & components are matched correctly....
Thanks in advance, Larry
benjaml1
Re: Speedo current draw ??
« Reply #1 on: October 26, 2009, 04:20:07 pm »
Update...One smoked speedo, with water cooling. I thought that this couldn't be right.. My first adventure into in FE  >:-o
Dreadstar
« Reply #2 on: October 26, 2009, 04:20:59 pm »
With no motor running,and only programming the esc,then no,it should not get warm.....ever. :o Re-check your wiring,as it sounds like you may well have a short somewhere,or the polarity is reversed somewhere.
benjaml1
« Reply #3 on: October 26, 2009, 04:23:09 pm »
Double & triple checked polarity I'm afraid & all was well....  Thank you for your input all the same... Cheers, Larry
Dreadstar
« Reply #4 on: October 27, 2009, 02:15:39 pm »
Just as a matter of interest Larry,what voltage were you planning on operating at? Too high a voltage is the only other way that the esc could heat up like that.
benjaml1
« Reply #5 on: October 27, 2009, 02:37:55 pm »
Running 6 Lipos on a 125A Suppo, the manufacturer rate it 4-6 Lipos...But it also crossed my mind... Thanks for your input.. :-))
Page created in 0.017 seconds with 20 queries.
