Author Topic: Graupner Voith unit  (Read 2826 times)
dms toucan
Graupner Voith unit
« on: November 06, 2009, 11:40:10 pm »
I need to put grease into the unit, how do you open it
without breaking it. Hope you can help
Regards Martin
poll
Re: Graupner Voith unit
« Reply #1 on: November 06, 2009, 11:46:38 pm »
Hi Martin
The water lubricates the unit, when you take it out of the water after a run, you should run the unit a couple of secs to empty the chamber. Hope this helps.
John.
Umi_Ryuzuki
« Reply #2 on: November 07, 2009, 09:57:24 am »
If I recall correctly,
Remove the belt from the drive pulley, then remove the small set screw in the top.
You can then unscrew the large drive pully from the unit's "drive shaft"...
It should just disassemble after that.
dms toucan
« Reply #3 on: November 07, 2009, 02:14:53 pm »
Thank you Umi
Regards Martin
