Author Topic: thicking glue  (Read 3431 times)
new start
thicking glue
« on: November 30, 2006, 09:05:32 pm »
does anyone know what kind of powder(or something else) that you can use for thickening glue (epoxy)
thank you
boatmadman
Re: thicking glue
« Reply #1 on: November 30, 2006, 10:36:37 pm »
Your friendly epoxy seller should be able to sell you some silica powder for thickening, its used in 1:1 boat building. You can also get wood flower, which colours the epoxy mix to something approaching natural wood.
gribeauval
Re: thicking glue
« Reply #2 on: November 30, 2006, 10:41:26 pm »
I steal and add the wife's talcum powder. It's cheaper than buying anything and smells a whole lot better than epoxy adhesives when sanding down!! 8)
True Lifeboat Nutter!!
boatmadman
Re: thicking glue
« Reply #3 on: November 30, 2006, 10:46:52 pm »
Guess talc is ok for model boats, but for 1:1 the silica powder adds a lot of strength.
How much talc do you use? or is it a case of just as much as the required consistency needs?
gribeauval
Re: thicking glue
« Reply #4 on: November 30, 2006, 10:51:55 pm »
As you say I just add enough to suit the job in hand. In most cases I only use the filler/epoxy mix when I have run out of car body filler and only need small amounts as it can be expensive otherwise!  ;)
FullLeatherJacket
Re: thicking glue
« Reply #5 on: December 01, 2006, 08:49:15 am »
