Aligning/installing the motor/shafts/rudders etc. is by far the most fiddly, frustrating ‘fun‘
. It’s a pain with a ready made wobbly grp hull and you have precut internal frame structure to modify - it’s much easier when you scratch build the hull from a plan - you can decide/pencil in alignment on the side elevation of the plan and extrapolate on the relevant structure/frames - all/every measurements to hand.
I'm assuming you have chosen motors/mounts and prop size (allowing extra clearance for fitting bigger props?) I used long dowel rod as substitute and splinted it ,including the coupling, onto the mounted motor(s) - I used sleeving/matchsticks/electrical tape - straight n' true. I then decided on my parallel (or splay) dimension and made a couple of temporary symmetrical frames/formers profiled to mount a) one for under the stern b) one for in the hull - both centred on the corresponding hull marks. (I cut these aligning frames out of thick cardboard, notched to locate/ensure parallel or splay of the shafts and maintain their equal symmetry/positioning. I used cellotape for temporary fixing - the cut and fit of the formers proceeds until the alignment/clearance of the assemplies suits/meets all criteria. Cutting/elongating slots through the hull for the shafts needs care and the rear of the boat's cradle may need to be modified to accomodate the protruding shafts.
It’s much easier to strap/support the bare wobbly hull into the cradle minus the internal framing and align the motor shaft assembly first - then cut n’fit the modified internal structure later. Offset rudders allow shafts/props to be removed easily and enable easier/more effective positioning of cooling venturi pickup fittings if needed. I found that the last measurement I obtained was the actual length of the propshaft - either choose nearest size/tweak installation or cut n’ file a pair.
I ‘resinned’ baseplate(s) on hull bottom and countersunk vertical mounting bolts for fixing engine mounts then shimmed each corner of the mounts with various washers to ensure straigt n' true alignment with released couplings.
Apologies if I’m droning on to the initiated but none of the above was obvious to me - I ended up with a hull like swiss cheese
- I can look back and laugh now
- Less pain more gain!
