May 11, 2025, 02:21:28 pm
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Mayhem at Wicksteed -
May 24 25
Home
Help
Search
Calendar
Login
Register
Mess Deck: General Section
Model Boating
Help with building
« previous
next »
Pages: [
1
Go Down
Print
Author
Topic: Help with building (Read 2681 times)
Alex
Guest
Help with building
on:
January 01, 2010, 12:19:29 pm »
Hello my name is Alex and I work on an Anchor Handling Tug Supply (AHTS) vessel called the Highland Courage, I would like to build a model of the vessel but every time I talk to any model organisations for assistance or ideas, I get a very negative response. I would like to make a working one but I would be quite happy to make a static model if the expense is too much.
I have access to all the ships plans and will be able to use them, so is there anybody out there that could give me an idea of where I can start???. I have made model Airfix kits before, for example I have just finished building a model of the Bismark which I am quite pleased with.
Alex
Bradley
Guest
Re: Help with building
Reply #1 on:
January 01, 2010, 01:10:06 pm »
Hi Alex,
Welcome to the forum. How about Model Slipway's 'Aziz'
(click on the link below) -
http://www.modelslipway.com/
Derek.
Global Moderator
Full Mayhemer
Offline
You bark - I will bite!!!
Fareham
Reply #2 on:
January 01, 2010, 01:40:07 pm »
Alex,
Look through some of the "Masterclasses" on here and you will get the basic idea of "plank-on-frame" building.
With the ships drawings there is more than enough information to make a hull and complete the model.
If you choose a common scale IE 1/32 or 1/48 there are many commercial fittings available which can cut down the building time considerably.
Full Mayhemer
Offline
www.srcmbc.org.uk
Southampton UK
Reply #3 on:
January 01, 2010, 02:56:46 pm »
Is this your ship Alex.
Richard
Solent Radio Controlled Model Boat Club
http://www.srcmbc.org.uk
RobinStobbs
Guest
Reply #4 on:
January 05, 2010, 07:58:42 pm »
Hi Alex,
I've made a few models (working) from drawings only - but then I've been making models of all sorts for the past 60+ years! My current magnum opus is a 1:32 scale model of one of the SAR&H harbour tugs which comes out at almost 1.5 metres LOA and a displacement of around 80kg. I have builders drawings plus dozens of pics as this vessel was greatly modified during her lifetime and so only the hull lines and deckhouse plans were of real use. Everything hand made except chain and LED lights!! ;-) Your best bet is bread an butter using obeche or jelutong and since you have all the builder's drawings a true scale model should be well within your reach. Shout me if I can be of further assistance.
Full Mayhemer
Offline
Huntingdon, Cambs, England
Huntingdon, England
Reply #5 on:
January 05, 2010, 10:51:11 pm »
Hi Alex,
Welcome aboard. As shipmate60 says you should have enough information to build a plank on frame hull. I'm working mainly from photos and a few drawings on Anglian Sovereign, which appears to have similar lines to the ship in Dickys photo. Here are a few photos of the hull build.
HTH
Doug
boater12
Guest
Reply #6 on:
January 05, 2010, 10:59:29 pm »
I can see where you are coming from with the shape, but as a master with BOURBON, FARSTAD, MAERSK and also the ANGLIAN SOVEREIGN, the hull is completely different.
The UT722L class is a different type of Anchor-handler.
Jim,
Full Mayhemer
Offline
Huntingdon, England
Reply #7 on:
January 06, 2010, 12:24:57 pm »
Boater,
I bow to your professional knowlwedge of these ships. Nonetheless, the photos will give Alex an idea of how to go about building the hull, which was my main aim.
Doug
Print
Pages: [
1
Go Up
« previous
next »
Model Boating
Help with building
