Author Topic: Surfacing  (Read 2543 times)
Ghost14
Surfacing
« on: February 14, 2010, 08:02:20 pm »
Hey Guys,
I have a couple of questions regarding how to finish the exterior of a hull of a boat.  In the past, I've simply sanded the hull down and covered it with 2 or 3 coats of oiled based marine paint... and that seems to do the trick however it is not as smooth or as shiny as I would like.  Do you guys have any materials or methods that you could send my way? Thanks for any and all help.
-Ghost-
Re: Surfacing
« Reply #1 on: February 14, 2010, 08:13:07 pm »
Whats the hull made of ?
barriew
Re: Surfacing
« Reply #2 on: February 14, 2010, 08:16:32 pm »
....and in which country are you located?
Barrie
ministeve
  • washing the decks!!!
Re: Surfacing
« Reply #3 on: February 14, 2010, 08:16:55 pm »
i always use halfords spray paint for my hulls red primer for under the waterline and get them to mix the right colour for whatever i am building works for me just be carefull not to mix the wrong 2 paint types or you will get a nasty crackling effect
Ghost14
Re: Surfacing
« Reply #4 on: February 14, 2010, 09:54:38 pm »
I'm working with balsa and from Maryland, USA
Re: Surfacing
« Reply #5 on: February 14, 2010, 10:13:27 pm »
Over here we would use sanding sealer followed by Aerosol primer and several coats of aerosol gloss paint as used in the automotive trade.
Rub down with fine wet and dry sandpaper between coats and make sure the surface is dry before applyng the next coat.
Make sure you use the same make and type of primer and paint, ie acrylic etc.
Ghost14
Re: Surfacing
« Reply #6 on: February 14, 2010, 10:51:58 pm »
Thanks for the heads up Richard.  I'll look into that!
Bradley
Re: Surfacing
« Reply #7 on: February 14, 2010, 11:00:43 pm »
Hi Ghost,
I believe that in the States the paint they use in the spray cans is 'Krylon' make.  :-))
Hope this helps.
Derek.
Page created in 0.127 seconds with 21 queries.
