My equipment is:
Viper Marine 25 driving a MFA (Como Drills) 919D motor from a 12 volt 'gel' battery. Radio gear is Hitec Ranger II on 26.995 MHz and linear distance from controller to receiver is about 180mm.
My problem is:
At full ahead the motor momentarily and intermittently cuts out for brief moments but at half ahead it does not do this. On full astern there is also no problem.
Attempted cures:
The 919D motor comes with a capacitor (of no indicated capacitance) between + and - leads. I tried adding a 100 uf capacitor to this - in parallel - with no success. I then tried a 10 uf capacitor between + and casing and another between - and casing and then this again with the 100 uf capacitor between leads. None of these combinations worked. I have also tried shielding the receiver with aluminium foil.
Any suggestions on a cure? Would braid screening/shielding around the servo leads help? The antenna goes directly from receiver up through the aerial tube. Might there be an internal problem with the Marine 25 controller (This is brand new and not previously used on any other model)?
I have Viper controllers in three other boats, one of which is a large tugboat with twin motor setup and two controllers which are only about 80-100mm from the radio receiver. This is the first time I am using the 919D motor and initially suspecting there might be a problem with the motor changed my setup with an identical unit - both had this cutout problem on full ahead setting.
Can somebody please come up with a suggestion before I turn said model into an artificial reef.
Rob
