Author Topic: sound module  (Read 4351 times)
hover tim
sound module
« on: March 24, 2010, 06:45:52 pm »
I am after a sound module that i can record one sound on (a Gas Turbine) and nothing elese i know that there is a new one out but its quite expenive and i wanted to see if there was anything elese on the market before i get on of the new ones any tips
FullLeatherJacket
Re: sound module
« Reply #2 on: March 24, 2010, 09:35:39 pm »
All of these will do as long as you only wish to replay a fixed sound or sounds. If you want to modulate the sound by remote control e.g. increase the "revs"of the engine  with the throttle, then they won't.
FLJ
HS93 (RIP)
  • I cannot spell , tough
Re: sound module
« Reply #3 on: March 24, 2010, 10:16:21 pm »
you could use this one with a simple Chinese switch to change between recordings , its cheap
http://www.cowlacious.com/AudioProd.htm
Peter
Re: sound module
« Reply #4 on: March 24, 2010, 10:40:23 pm »
Peter
It appears that they sell the kit with or without the chip, but dont seem to list the chip separately.  Googling, there are some UL suppliers of similar sounding items.  Finding somebody willing to sell the ISD17xxx in quantities less than a truckful might be a problem.  I used an earlier version years ago, before Maplin figured out it was a useful item and therefore discontinued the line.
HS93 (RIP)
Re: sound module
« Reply #5 on: March 25, 2010, 12:48:22 am »
I built a board from a magazine article called some thing like "can be anything" that i think had this chip still works great my mate wants it to play messages to fellow sailors in his boat for some reason. there was a board that was available at the time for  few pounds, it was a good project
FullLeatherJacket
Re: sound module
« Reply #6 on: March 25, 2010, 09:10:07 am »
http://uk.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=0543948
240 seconds recording time. The other ones is 120 seconds and is now discontinued.
Happy soldering!
FLJ
Re: sound module
« Reply #7 on: March 25, 2010, 09:23:16 am »
Good find - the only trouble for the average home builder is that that particular one in the link is a surface mount device, and would present difficulties using with a chip socket.  The only ones that are DIL appear to be a 16 second one (great for gun fire, hooter, etc., but probably limited for engines), and a 16 minute one, both with different pin-outs and therefore not usable with that particular circuit.  Aren't some outfit called Action doing something like that?
PMK
Re: sound module
« Reply #8 on: March 25, 2010, 10:34:13 am »
Malcolm, maybe fabricate yourself a small adaptor-pcb to convert S0IC's to DIL?
FullLeatherJacket
Re: sound module
« Reply #9 on: March 25, 2010, 11:59:01 am »
.......... its quite expenive..............
Can't please everyone all the time, Doc.
FLJ
Re: sound module
« Reply #10 on: March 25, 2010, 04:14:18 pm »
It not me that needs one - I built my own years ago before Maplin deleted sound recording chips from their portfolio when they found out they could be useful.
Subculture
    • Dive-in to Model submarines
Re: sound module
« Reply #11 on: March 25, 2010, 06:06:03 pm »
http://www.electronics123.com/s.nl/it.A/id.2841/.f?sc=8&category=2
http://www.electronics123.com/s.nl/it.A/id.2734/.f?sc=8&category=2
http://www.scary-terry.com/dsr/dsr2.htm
http://www.4dsystems.com.au/prod.php?id=73
The last one is a neat little MP3 player which you can interface with pushbuttons (or servo operated microswitches) or a microcontroller (e.g. Picaxe) via a serial link for advanced operation. It's tiny and quite inexpensive. You will need an amplifier  for reasonable volume. Maplin do a couple of Velleman chip based amplifier kits which are okay.
Page created in 0.016 seconds with 22 queries.
