Author Topic: vac form hull  (Read 2733 times)
sentry
vac form hull
« on: April 05, 2010, 12:27:40 am »
Gent's
Can I coat the inside of my vac form hull with resin to make it stronger and if so how do I go about it.
                                Regards Sentry.
brianc
Re: vac form hull
« Reply #1 on: April 05, 2010, 12:43:20 am »
You could,but why would you want too?
I`ve built a few models based on vac form hulls and its amazing how much a nice basla framework and a couple of bulkheads strenghen them up :-))
Depending on how light the hull is,you could end up distorting it by the heat generated by the curing resin or even fixing any inaccuracies or twists into the hull permanently
Just my opinion ;)
Re: vac form hull
« Reply #2 on: April 05, 2010, 07:48:02 am »
I think a few people have tried a fibreglass matting but you have to watch out for the hear it generate when curing and
may find that you have to glue it on with PVA afterwards anyway. As BigBri says you may have to make up an internal
keel and bullheads from wood or plastic. Test your glues thoroughly first!
sentry
Re: vac form hull
« Reply #3 on: April 05, 2010, 06:53:10 pm »
Thank you Big Bri & Martin,
 Think I,ll just keep to the plastic  bulkheads seams a lot safer.
                                                Regards, Sentry.
Jonty
Re: vac form hull
« Reply #4 on: April 06, 2010, 02:59:21 pm »
  Don't risk it - polyester resin will probably dissolve the plastic of the hull.
I eat my peas with honey,
I've done it all my life;
ZZ56
Re: vac form hull
« Reply #5 on: April 07, 2010, 02:14:07 am »
You could use an epoxy resin, but it's much more expensive.  Better to go with styrene or Sintra bulkheads.
Re: vac form hull
« Reply #6 on: April 07, 2010, 10:37:04 am »
And for your plastic bulkheads you could use the corrugated type used for the estate agent "For Sale" signs. Lightweight and rigid.
  Regards  Ian
Page created in 0.026 seconds with 22 queries.
