Author Topic: Running time  (Read 3562 times)
john1951
Running time
« on: April 09, 2010, 06:24:45 pm »
My Deans Marine Royal Marine trawler is powered by 4 AA batteries.
           What length of running time can I expect from them ?
Re: Running time
« Reply #1 on: April 09, 2010, 06:36:24 pm »
What motor and what prop, what amperage batteries ?
john1951
Re: Running time
« Reply #2 on: April 09, 2010, 07:03:18 pm »
Motor is a modified servo, the prop is a 1" diameter 3 blade, but I have no idea as to the battery amperage, just that they are the usual 1.5 volt rechargeable.
Re: Running time
« Reply #3 on: April 10, 2010, 10:18:37 am »
With a similar setup in a converted Lindberg trawler, I get a good hour and a bit.  A lot "depends" - higher capacity AAs last longer, constant flat out will shorten run time.  Its a mile round "my" lake, and it will take me for a walk round, then allow a reasonable time to mess about when I get back to the start.  I was using 1000mAH cells, that capacity being the state of the art at the time. Newer ones are likely to be much higher.
john1951
Re: Running time
« Reply #4 on: April 10, 2010, 11:54:42 am »
Thanks Malcolm, mine are 800mAH, so I think an 1 hour would be about right at Trawler speed !
        Cheers      John
stallspeed
Re: Running time
« Reply #5 on: April 10, 2010, 05:03:01 pm »
John,If a 2kgcm servo has a 300:1 gear then its motor has a stall torque of 7gcm.
Compare that figure to some more familiar motors.
dodgy geezer
Re: Running time
« Reply #6 on: April 10, 2010, 05:17:20 pm »
.....  I was using 1000mAH cells, that capacity being the state of the art at the time. Newer ones are likely to be much higher.
Current top-end NiMH AAs are speced at about 2500mAh. But you can buy 1000mAh ones at half the cost...
Re: Running time
« Reply #7 on: April 10, 2010, 05:29:20 pm »
That'll be because they last less than half the time then. O0
Re: Running time
« Reply #8 on: April 10, 2010, 05:34:15 pm »
Current top-end NiMH AAs are  2900mAh £4.75 for four at Component Shop.
http://www.component-shop.co.uk/html/body_aa.html
dodgy geezer
Re: Running time
« Reply #9 on: April 10, 2010, 09:33:15 pm »
That's a very good buy. The shipping is low as well.
I have some Sony batteries specced at 2800mAh, but I'm a bit suspicious of whether you actually get these high figures in practice. Still, they are probably well over 2000mAh....
Page created in 0.331 seconds with 23 queries.
