If you tried to put a gas turbine in a swordsman, even a small one such at the MTT unit, you better have a bl*** big swordsman. You also just have better one the lottery. Wren turbines are generally quite cheap, so lets say you wanted a Wren 44 turboprop motor to put in this thing. So you've managed to get money together the to get the engine, ECU, data terminal, valves, pump, mounts, pipework, connectors, gas tank and a radio system good enough to handle the functions, do any of you have the first clue how to wire one together and start it? No thought not. Also, who's going to insure you?
The turbine itself by the way is £2999
Then comes the problem of getting a swordsman big enough, you'd need one around 6 feet long to handle the power of the turbine.
I think we can discount the chatter of turbines now?
