Author Topic: MUSTANG TUG (model slipway dutch courage)  (Read 10580 times)
debssnal
« on: April 17, 2010, 09:23:45 pm »
Hi everyone,
                 this is my new build Mustang based on the model slipway dutch courage.Mustang was Delivered March 2009 and the Owner is G. Bouwman Towing & Shipping B.V.
Well here we go then,i have turned the Kort nozzles on my lathe to make them look better.
here are some pic,s so far.
regards
Alan
Number 6
Re: MUSTANG TUG (model slipway dutch courage)
« Reply #1 on: April 18, 2010, 08:36:45 am »
Hi there, is this one going to take as long as the coaster? Don't know how you build them so quick and to such a high standard. Congrats on the lgv, I've been driving them for several years and thoroughly enjoy it. Be seeing you..Number6 :-))
seahawk 1
« Reply #2 on: April 19, 2010, 04:31:24 am »
 Looking foward to your build.  :-))
debssnal
« Reply #3 on: April 19, 2010, 11:53:04 pm »
Hi everyone,
                 bit of a slow day today.i have been fitting the running gear today.i am going to fit the tug with four rudders,as the full size tug has.i have turn the rudder bearings,they are made in two parts.the first is 25mm long i drill a 4mm hole all the way through.then i drill it out to 6mm but only 20mm deep.then on the second part it is 10mm long,but i turn 5mm of it down to 6mm.you put the two parts together and there is your bearing.you fill with grease fit the rudder post and rudder and there you are a water proof part.this is made erom 8mm brass rod.
here are sum pic,s
debssnal
« Reply #4 on: April 20, 2010, 10:38:30 pm »
Hi everyone,
                 had a good today on the tug.got a lot done.
have a look eor yourself.
kind regards
Alan
debssnal
« Reply #5 on: April 23, 2010, 08:45:04 pm »
Hi everyone,
                 i am going to fit this tug with two brushless motor.this is not for speed it for power.they are low rpm out runners.they are 600kv and i am going to run them on 6 volts =3600rpm.shoud have some more pics to moz.
kind regards
Alan
debssnal
« Reply #6 on: April 25, 2010, 09:48:29 pm »
Hi everyone,
                 i have now fitted the brushless motors and esc,s
here some pic,s
kind regards
Alan
debssnal
    • http://www.ateamboatyard.co.uk/
« Reply #7 on: April 30, 2012, 10:23:44 pm »
Hi Everyone,time to get some more done on the tug.
I have made the rudders tonight.
Here are some pictures
regards
Alan
« Reply #8 on: May 01, 2012, 01:22:10 pm »
What are the motors?    :-)
chipchase
« Reply #9 on: May 01, 2012, 10:55:17 pm »
Nice build Alan, I like your idea for sealing the rudder shafts. Do you think 3600rpm will be enough power for the Mustang
Brian
Page created in 0.02 seconds with 21 queries.
