if it's on a non conducting mast then i use multi strand wire and strip it , i then run two seperate strands of wire up each side on the mast and make my solder connections . this is ideal for led lights , if you require more power then use brass wire in the same way . Once the connections are done then paint over the wire and mast to hide it .
daz
