Author Topic: Deans Marine Dufresne Question  (Read 3786 times)
asimmd
« on: May 17, 2010, 01:28:30 pm »
Hi All
Can anyone please tell me what motors would be suitable for the Dufresne.
Also,being  a twin,do I need 2 esc's?
If not,how would I control the speed on each motor?
Alan
Re: Deans Marine Dufresne Question
« Reply #1 on: May 17, 2010, 01:36:28 pm »
Ask Deans about motors.
Fit Action P94 this includes 2 speed controllers and a mixer which works 4 different ways.
http://www.action-electronics.co.uk/pdfs/P94.pdf
Speak to Dave at Action he will sort you out.
« Reply #2 on: May 17, 2010, 03:10:23 pm »
To control 2 motors independently you will need 2 speed controllers. You can then either:
use two radio channels and control each motor manually ie right and left thumb.
Or
Use a mixer with one radio channel. The mixer tends to slow the inner motor when turning and can reverse the inner motor on full rudder giving the opportunity to turn in the boat's length.
If you opt for two channel control of the motors you do not need a mixer.
In my experience a mixer allows easy control form the outset but the control mix is set by the mixer. Independent control is more flexible but takes a little practice to master.
HTH
Doug
« Reply #3 on: May 17, 2010, 05:15:38 pm »
Is this the 1 from the Bath area?
asimmd
« Reply #4 on: May 17, 2010, 05:17:53 pm »
I think so,I won it on ebay.
Alan
« Reply #5 on: May 17, 2010, 09:21:07 pm »
What motors do Deans recommend?
What voltage is preferred?
Was there any props with her?
asimmd
« Reply #6 on: May 17, 2010, 09:39:55 pm »
Hi Bob
Comes with 2 Brass Props and rudders,I emailed Deans and this is the reply.
Suggested is 2 x kondor 11 motors + 2 x nycrome exl couplings 2.3mm / M4
They don't say whether 6 or 12 volt,I think I will go for 6 volt,unless someone
advises otherwise.
Alan
« Reply #7 on: May 17, 2010, 09:57:26 pm »
Deans usually quote for 7.2 volts.
« Reply #8 on: May 18, 2010, 08:12:15 am »
Have several boats with Deans Kondors and as Bob says, all run on 7.2v, should give nice scale speed. :-))
« Reply #9 on: May 18, 2010, 09:08:06 am »
Nice one just went on ebay for £157
asimmd
« Reply #10 on: May 18, 2010, 10:33:05 am »
Hi Martin
That nice one that went on ebay is the one I won,with 3 seconds to go.
I thought the price was good,and as you say,it looks like a nice model.
I wanted something to sail while building my Loyal Class Tender,and I have always
liked the Dufresne.
Alan
Page created in 0.016 seconds with 22 queries.
