Author Topic: Does anyone still buy Futaba?  (Read 13170 times)
vintagent
Re: Does anyone still buy Futaba?
« Reply #25 on: May 19, 2010, 10:25:04 am »
Yes, Circlip, you confused me there, did you mean surface and boats-40 moggies?
Vintagent
Arrow5
« Reply #26 on: May 19, 2010, 10:38:01 am »
35mHz is NOT for surface use. >>:-( <*<
..well can you land on this?
« Reply #27 on: May 19, 2010, 12:36:33 pm »
SORRY GUYS, PLEASE kick it  ;D  Trying to multi task, read, think and type all at once.
  Yes, 35 Moggies was, is and forever more will be AIRCRAFT ONLY
  40 Moggies Surface and Toy Boats ONLY
  Regards Ian.
The long Build
« Reply #28 on: May 19, 2010, 01:08:05 pm »
So how is a flying boat plane defined , eg Shorts Sunderland..  %%
andyn
« Reply #29 on: May 19, 2010, 01:23:22 pm »
Flying boats are for 35 moggies or 2.4 giggling moggies
The long Build
« Reply #30 on: May 19, 2010, 01:25:14 pm »
Just as I thought , have now found a use for my Futaba 7 channel 35mhz..
« Reply #31 on: May 19, 2010, 01:46:26 pm »
The difference in full size is that seaplanes have floats while flying boats land on their hulls and the floats are stabilisers.
As far as models are concerned the distinction is between 'surface' and 'air' so if you were to make a model Sunderland that is only capable of swanning around on a pond and cannot become airborne it must be treated as a surface model - 40 moggies. If it can take off then it would be treated as a plane - 35 moggies. Just because it takes off from water rather than land doesn't make it any less of a plane.
35 moggies was introduced to reduce the likelihood of interference from other types of R/C model and hence the likelihood of innocent members of the public being decapitated by out of control high powered flying objects. Just common sense really.
« Reply #32 on: May 19, 2010, 04:47:20 pm »
Yep, and someone arsked "What about Hovercraft??"   O0
  Regards  Ian.
  Just remembered, in the early days of the 35Moggy saga, Hitec came out with a 35Mog AM set. O0
Page created in 0.024 seconds with 23 queries.
