Author Topic: Propeller size according to ship size?  (Read 3738 times)
highvoltage
« on: May 27, 2010, 09:37:22 pm »
I am starting a build. ULSTEIN SX121. I am doing it 1:48 scale so it will be approximately 8' long.
I am looking to get nozzles that house a 95mm prop. My question is will that be okay? Or could I get away will smaller props?
Thank you
Re: Propeller size according to ship size?
« Reply #1 on: June 01, 2010, 07:27:07 pm »
I have a table, gleaned from one of the many modelling books I have read over the years, which suggests a 50mm prop for a 48 inch boat. Doubling up you get 100 mm for an 8ft boat, so 96 seems good. However, the table is for a single prop boat suggesting you could drop the diameter for a multi prop. How many are you fitting? What size props are fitted to the original?
HTH
Doug
boatmadman
« Reply #2 on: June 01, 2010, 08:32:42 pm »
John,
Looking forward to seeing the build.
Where did you get the plans?
Ian (part way into building a Bourbon Orca)
highvoltage
« Reply #3 on: June 01, 2010, 09:33:16 pm »
HTH
Doug
There will be 2 mains. I ordered 100mm 4 blade props. So that should be good...
highvoltage
« Reply #4 on: June 01, 2010, 09:34:40 pm »
John,
I just went off there website and made my own templets for the hall. It not going to look just like theres I adding my own flair to it.
boatmadman
« Reply #5 on: June 01, 2010, 10:14:10 pm »
John,
Dont know if you have seen my build thread, here:
http://www.modelboatmayhem.co.uk/forum/index.php?topic=17422.0
Ian
highvoltage
« Reply #6 on: June 01, 2010, 11:21:35 pm »
Yes sir. I saw you build. Actually I saw the post that said wierd hull design (or something like that). Then I saw a link to your build.
Your build is very nice. Thank you for sharing the photos.
highvoltage
Page created in 0.033 seconds with 22 queries.
