Author Topic: Set up of speed controller  (Read 2621 times)
sausages
« on: June 05, 2010, 06:02:24 pm »
Hi
Can anyone please advise on folllowing :  I have twin Graunpner 600 ECO electric motors installed in my boat,I have acquired a Ripmax Sea Sprint FNR 36T (bit confused with the spec ) would this be man enough for the motors,? could I run the Sea Sprint  without water circulation ?
Many Thanks
red181
Re: Set up of speed controller
« Reply #1 on: June 05, 2010, 11:04:50 pm »
this seasprint requires water cooling as it has no heat dissipation plate, assuming its going to be used at its potential. Ignore the stated Ripmax spec, its a load of rubbish, by memory something ridculous like 200amps! I have had a couple of these, they are good, be careful of the wires that attach the on/off switch, very prone to breaking off. I had this problem under warranty, and whilst dealing with Ripmax I challenged the stated specs, they just could not justify them, some sort of stupid calculation, it actually has a stated amp draw more than the electrical circuit on a house :}
It will only power one motor, will not be capable of powering 2, for that you need a esc that is better, such as electronise 35amp
You need a seperate BEC 6 volt supply, which is the only draw back, but its also reverse which is a bonus. You cant get them now, so treat it well :-))
If it transpires that you dont need it, pm me I would be interested in buying it!
Paul
sausages
« Reply #2 on: June 09, 2010, 05:10:42 pm »
Hi   Thanks for the imput .I wont be selling the Sea Sprint as I have another model I can use it in.
Have you any idea what amp rating the sea sprint is? and once again cheers for the Info.
Mike B
Page created in 0.757 seconds with 21 queries.
