Author Topic: 49" perkasa  (Read 2303 times)
glyn1
49" perkasa
« on: June 11, 2010, 08:12:35 pm »
hi all
i am very new to this hobby and i am looking at all sorts of boat kits.  I am just looking at the Perkasa 49", the one with the grp hull.  As i have never built anything before, could anybody advise as to weather this model would be ok for a 1st time novice builder?  Any advise greatly appreciated. Glyn
Re: 49" perkasa
« Reply #1 on: June 11, 2010, 08:30:32 pm »
Hi Glyn and welcome the the club.    :-))
I hope you enjoy yourself on here as we have a varied assortment of skills on offer.
There is a very strong leaning to the Perkasa here, although I myself haven't had time to build one yet. I'm sure other members would be only too willing to give you assistance. It is a nice craft and I may try one myself one day.   Have a browse through the search engine and you will find most of the info you require.
Ken
Perkasaman2
Re: 49" perkasa
« Reply #2 on: June 11, 2010, 11:25:40 pm »
Hi glyn1, The Perkasa kits are very good value, especially the grp hull versions. The 49 grp kit contains all the building materials required to satisfactorily complete the hull and superstructure. A lot of the timber parts are on 'die cut' sheets of lite ply and clearly numbered, but be prepared for a lot of cutting/sanding, also there's a 'few'   %) balsa blocks to shape. Generally speaking, there's quite a bit of 'fettling' needed to achieve a good 'fit and finish'. Care and effort is needed, but the result is impressive, whatever level of finish. These 49's look very impressive on the water, especially at speed. These boats are lightweight and plane easily on i.c. or electic power.
http://www.modelboatmayhem.co.uk/forum/index.php?topic=17381.0
The 'raw' materials to create a 'semblence' of the weapons and fittings are also included, however, most builders tend to source more detailed alternatives to enhance their finished  boats.
Full clear building instructions are included and a very useful information booklet containing facts/ photographs of the original for adding detail.
The bow of the Brave Class (Perkasa)  is not faithfully reproduced in any of these kits. The grp hull is a replica of the wood hull where thin sheet ply is wrapped around the stem to plate/form the bow above the chines, however, I'm sure most folk don't really notice. This compromise, was made to simplify building, although I did attempt to modify one  my hulls with a bit of 'cut and shut' to approximate the bow on the original......... and wasted time.   %)
Larger boats are certainly easier to work on and this kit is not tough....................... follow the 'destructions' carefully and your patience will be rewarded; the learning curve is'nt steep and the skills you will acquire are a plus for the future. There are easier, smaller kits at double the cost but this big kit, in spite of it's faults, builds into a great  model.   :-)
glyn1
Re: 49" perkasa
« Reply #3 on: June 12, 2010, 08:53:17 pm »
thanks for the welcome and the info might give it a go, i am going to the local boat club i have found to have a look on sunday so might see something there that catches my eye. I got a kyosho seawind today so i can get on the water while trying to build something lol
