Author Topic: INFO ON MODEL STEAM TURBINES REQD  (Read 4988 times)
Klunk
« on: July 18, 2010, 03:11:15 pm »
Anyone got any info on the above???
full time penguin
dreadnought72
Re: INFO ON MODEL STEAM TURBINES REQD
« Reply #1 on: July 18, 2010, 03:42:25 pm »
Saito used to make one - but I believe, like model jet engines, there were bearing problems at multi-tens-of-thousand revs. Meanwhile, all model turbines (which seem to be single-stage and use an impellor and therefore slurp kinetic energy, rather than blades and gas pressure) are steam-hungry.
I'm not sure why there's been little, if any, interest in Tesla turbines for models. (You get rotation from a steam jet without the need for difficult-to-make balanced turbine blades. The axis of a Tesla turbine would emit low pressure steam/water, and might offer some of the benefits of a condenser without (umm) having a condenser.
All these small-size turbines would need gearing - quite drastic gearing in many cases - to reach normal model propellor revs.
A raft of problems.  %%
I wonder if there's a preference to seeing cylinders and pistons "doing their thing" in the live-steam world, rather than plugging in some covered turbine and getting little more than a rotating shaft and a whine out of it?  %)
gondolier88
  • www.coniston-regatta.co.uk
    • Coniston Regatta
« Reply #2 on: July 18, 2010, 03:56:42 pm »
Hi Klunk,
There is a raft of info on Tesla turbines out there- may we ask why?
Greg
dreadnought72
« Reply #3 on: July 18, 2010, 04:02:27 pm »
Tesla turbines work in reverse, too: might be a great way to make a bow thruster. You'd have a pipe in the bottom of the boat to feed water into the axis, then spin it up either way to force water out port or starboard.
Just a thought.
tony52
« Reply #4 on: July 18, 2010, 04:05:21 pm »
Commercially available r/c unit available from French company JC-Steam. Note: the website states 'Closed until March' but which March? March 2009 or 2010? Reminds me of when that annoying sign is seen in a shop 'Back in 5mins'. Why do they not stae when thy will reopen e.g. back at at 2:30pm.
http://jc-steam.com/estore/product_info.php?products_id=401
Tony
Klunk
« Reply #5 on: July 18, 2010, 05:10:11 pm »
some one in the club was asking about them and was interested if one had been made!
full time penguin
« Reply #6 on: July 18, 2010, 10:46:32 pm »
Loads of info Klunk, what do you need.
There are several being made at the moment, including one in a flash steam hydroplane.    :-))
Klunk
« Reply #7 on: July 19, 2010, 07:52:45 pm »
I knew this would drag you out of the woodwork Phil!!! Will get the relevant club member to my house so he can research it, he has no computer!!!
full time penguin
